Track Day Report @ PIR - boost spiked up to 20+psi(8-6 autotune setting was at 19psi)
08-12-2010, 03:08 AM | #1 |
Rep 4,647
i was at the track for 5+ hours. had 16 runs. i have had cylinder 5 and 6 misfire issues for few months now which is not coil or spark plug related issue so i'm thinking either hpfp or injector... outta warranty no fun...
anyways, long story short, best time was done at my 14th run of the day out of 16 runs (there was an accident caused by some dragster towards the end of the night which resulting in ending the night early for everybody; otherwise i would've ran 20+ runs). No meth. peak bosot @ 18.2 psi. 1/8 of 92 Oct + 3 gal of trick 101 unleaded race gas so i don't know what that comes out to be... (anyone?) R/T ... .114 60' ... 1.971 330 ... 5.421 1/8 ... 8.194 MPH ... 90.57 1000 ... 10.533 1/4 ... 12.481 MPH ... 115.89 9 outta 16 runs were worthless with misfires (didn't even hit 100mph and most of them less than 13s). 3 at 13 flat and 5 at 12s; 12.820, 12.677, 12.481, 12.584, 12.485. anyways, the interesting thing happened after the track event... on my way home i smash the gas and boost spiked up to 20.8 psi. i drove kinda hard on my way back in order to make a best out of remaining race gas and hit 20+ psi few times and eventually got limp mode at another 20.8psi so i granny back home from thereon. it consistantly hit 19.x psi during the track event too so i don't know if my setting is off or what... even at pump gas, autotune let the peak psi to pump up to be around 16.x psi... so... why am i getting all this high boost psi compared to others getting around 15.x...? just fyi, my starting point was only 30% which would be 13 psi... autotune bump all the way up to 16. and with race gas it goes up to 19 psi... is that normal? i don't even have meth......... yet not that i'm complaining but just to see how everyone else is doing because i've dig around few thread and it seems like everyone with procede autotune who has stage 3 bolt on without meth are getting around 15.5psi-ish... maybe shiv can shed some light into this?
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers Last edited by hun77777; 08-12-2010 at 04:04 AM.. |
08-12-2010, 06:57 AM | #2 |
658
Rep 10,587
IMO your running too much boost for your gas and conditions....what did your timing logs look like?
your trap speed is low for that boost......... you should really concentrate on getting the car running right hardware wise as well.
08-12-2010, 07:35 AM | #3 |
Team Zissou
3078
Rep 10,198
what do you have your max boost limit set to? sounds like it's set too high. also if you have misfire issues you should probably get that fixed before going to the track
08-12-2010, 11:15 AM | #4 |
Rep 4,764
I noticed short spikes above the max boost setting, at shifts (6MT) with <25 firmware on the vent gauge. So far with firmware 25 they are gone. More testing later today.
08-12-2010, 11:33 AM | #6 |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
The autotuned boost settings of 16psi and 19psi on pump and pump/race gas are reasonable given drag race conditions (12 sec at a time wot, high rpm only). But running your car when you have a hardware problem (hpfp, injector, etc) is a recipe for disaster. You really need to sort that out before anything else.
08-12-2010, 11:36 AM | #7 | |||
Rep 4,647
i couldn't get up to higher trap speed because those 12 sec runs, i had to shift from 3rd to 4th way earlier in order not to get misfire (@ around 5.5kish), hence lower trap speed... my misfire issue was not severe, or i thought at least until today, because it didn't even happen on street most of the time. it just happens once in a while and so i didn't even bother until yesterday. now that i know, i'll be on top of this... Quote:
misfire issue i was having wasn't severe and at the end of the trap it just goes away and i already paid for the track so i just wanted to make the best out of it...
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers |
08-12-2010, 11:37 AM | #8 | |
Rep 4,647
08-12-2010, 11:41 AM | #10 |
1743
Rep 17,960
Drives: A Lot
08-12-2010, 11:44 AM | #11 | |
Rep 4,647
08-12-2010, 11:45 AM | #12 | |
1743
Rep 17,960
Drives: A Lot
But the bigger picture here is you needing to sort out your car before racing it. Last edited by OpenFlash; 08-12-2010 at 11:56 AM.. |
08-12-2010, 11:46 AM | #13 |
Rep 4,647
08-12-2010, 12:26 PM | #14 |
Rep 4,647
is there a difference between 6MT and 6AT as far as boost spike goes?
08-12-2010, 12:32 PM | #15 | |
1743
Rep 17,960
Drives: A Lot
This is why datalogging is important if you really want to see what is going on. Things like peak hold displays only give you a snapshot of one particular condition that you really don't care about too much. But again, get your hardware issue solved before doing this kind of stuff. Autotune assumes that everyone else is working functionally. It has no way to compensating for a misfire issue. Whatever the cause may be. Shiv |
08-12-2010, 12:44 PM | #16 | |
Rep 4,647
i'll probably get hardware issue squared away but if you have to guess what other possibility is there other than hpfp or injector? misfires only on cylinder 5 and 6 and i swapped around coil and spark plugs to see if it's coil or spark plug problem but misfire symptoms still persist on same cylinder which tells me it's neither coil nor spark plugs... i really hope it's not injector... which will cost me pretty penny...
08-12-2010, 12:46 PM | #17 | |
658
Rep 10,587
are those boost numbers your quoting a solid # or just something you saw on your peak recall? datalog and report back please
08-12-2010, 12:50 PM | #18 |
Rep 4,647
16.x psi on pump gas is solid numbers based on procede program on netbook. i'll try to datalog...
08-12-2010, 12:51 PM | #19 | |
1743
Rep 17,960
Drives: A Lot
Last night, StartupJunkie was running his stg3 6AT at the track with race gas and meth. Boost climbed up to 20psi and ignition correction down to 0%. Stayed there the whole night with aggression level in the .5-1 range. Car ran 11.5-11.6 @ 124.5mph despite his.. ahem... dedication to the right pedal |
08-12-2010, 12:56 PM | #20 | |
Rep 4,647
08-12-2010, 01:01 PM | #21 |
30
Rep 314
Drives: 07 BMW 335i Sedan+2 Baby Seats
Thanks Shiv - yes, I'll post more of my results ... I beat my PR, but there was a lot more left in the car. I'll explain in a different thread. (/@sshat_on)
Junk
11.535@124.423mph (1.641 60') - AutoTune 7-27, Race+Meth, Best ET w/ only 80% throttle 1st and 2nd
11.647@121.356mph (1.590 60') - AutoTune (beta pre-5-15), Race Gas, No METH Perf Mods: Vishnu PROcede Rev3 v5, Vishnu PWM Meth Kit, AR Design DPs, AE Exhaust, Helix FMIC, Vishnu DCI, Forge DV, WaveTrac LSD (Best Trap - 124.665mph) |
08-12-2010, 01:20 PM | #22 |
Team Zissou
3078
Rep 10,198
