Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Seafoam 335d?
      08-13-2010, 01:26 AM   #1
kc1337
Drives: 4 wheels
Seafoam 335d?
Has anyone seafoamed the 335d to help with the issue of carbon build up that is plaguing all DI cars?
I wanna know how to do it on the 335d before the issue of carbon build up arises, so it'll be a bi-annually thing.
      09-03-2010, 12:51 AM   #2
kc1337
Drives: 4 wheels
Anyone?
      09-03-2010, 04:23 AM   #3
hun77777
hun77777's Avatar
Drives: SG E92
there are several people on e90 did seafoam on N54 but i'm not sure about diesel platform... i woul think it'd be pretty much same though...
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers
      09-03-2010, 05:16 AM   #4
SfValley335i
Afghanistan
164
Drives: Current:135i Sold:335i sedan
Here you go....
http://lmgtfy.com/?q=seafoam+diesel+engine
      09-03-2010, 10:20 AM   #5
BMW Junkie
Drives: '11 335d, '03 325i
2014 BMW X5 x35i  [0.00]
2003 325i  [0.00]
2011 335d  [0.00]
LOL! I love the link. Not only does it belittle you, but it helps you out as well!
      09-03-2010, 04:02 PM   #6
raceyBMW
king of the hills
raceyBMW's Avatar
92
Drives: 2011 M3 w/ESS55, 2001 540i/6
2001 BMW 540i/6  [8.17]
1994 530i  [9.00]
2007 335i Coupe  [8.37]
NO! Do not add Seafoam (or any top engine cleaner) to the intake manifold of a diesel engine as there is a good likelihood of hydro-locking the engine. Compression in Diesels is very high, and there is very little tolerance for adding a non-metered liquid in there along with the air.
You can add to the crankcase or fuel tank safely, but that will not clean the intake valves obviously.
      09-03-2010, 04:11 PM   #7
DieselDiner
DieselDiner's Avatar
486
Drives: 335d
+1
From the Seafoam Sales website:
Most people that own and work on Diesel cars and trucks know that no liquids can be used through the air intake system of a Diesel engine including cleaners and starting fluids. If this is done to a Diesel engine it can cause major engine damage including Hydro-Lock or uncontrolled engine acceleration known as “RUN AWAY”. Do not add Sea Foam to the air intake of a Diesel engine!!
They recommend this:
Get engine to operating temperature then shut off. Remove the fuel filter (replace filter if needed.) Empty all diesel fuel from filter or filter housing and fill filter or housing with straight Sea Foam. Reinstall filter on engine, making sure there is no air in filter. Start engine and let run about two minutes, then shut engine off and let sit about 5 minutes. This is called a “HOT SOAK” letting the Sea Foam soak into the carbon. After the “hot soak” period, restart the engine and road test, driving aggressively for about 5 miles. This will clean carbon from the injectors and the combustion chamber inside the engine.
      09-03-2010, 04:16 PM   #8
raceyBMW
king of the hills
raceyBMW's Avatar
92
1994 530i  [9.00]
Just another point, if you are getting serious coking on the valves, don't forget to check the EGR and PCV/breather, as these are usually the first things to get clogged up on a diesel. Most likely to clean the valves properly on a diesel, you will need to remove the intake manifold and clean them individually, this is really the only safe way.
Typically, diesels have very little room between TDC of the piston and the valves, so anything in the cylinder that isn't metered can easily cause damage.
      09-03-2010, 09:58 PM   #9
hun77777
hun77777's Avatar
Drives: SG E92
so it's ok on 335i but no good for 335d
      09-03-2010, 10:00 PM   #10
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2021 M5 Competition  [0.00]
2016 BMW 550i  [0.00]
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
Not in the same fashion that you'd do it on an i, that's correct.
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i
