335 owners - misfire at idle?
01-09-2007, 10:00 AM | #1 |
630
Rep 1,649
Hey guys, I wanted to see if others are experiencing a similar thing with the 335. I don’t think this is the “cold start idle” issue because it happens when the car is warmed up and driven for awhile. Basically I come to a stop at a light and the idle goes to 600 per normal operation and then randomly there is a miss. Very noticeable as the whole car kind of shakes once. No surging or oscillating rpm afterwards just 600 rpm again. It is quick so there is no drop in rpm either. I have this happen pretty regularly but no check engine light. I hooked up the OBD2 scan tool and there are no stored codes either. Any one else having the same thing?
I am hesitant to take it into the dealer after the disaster I had with my E46 idle issues. 7 different trips to the dealer, weeks of total time in the shop and in the end I got a pat on the butt and told by BMW field engineer that the idle problems I documented very well using OBD2 Data logging were “normal”. |
01-09-2007, 10:32 AM | #2 |
Rep 125
Yes, I wont say it's a misfire, but a definite one time 'shudder' about 10-15 sec. after coming to a stop in Drive or Sport.
335i Sedan, Step, 1700 miles |
01-09-2007, 11:20 AM | #3 | |
630
Rep 1,649
Exactly. If not a misfire (lack of spark, lack of fuel, etc.), then what would create this kind of situation?
01-09-2007, 11:26 AM | #4 | |
Rep 125
01-09-2007, 05:20 PM | #6 | |
630
Rep 1,649
I would not be surprised if it turns out to be slightly imperfect code due to first year production.... |
01-10-2007, 09:10 AM | #7 | |
Expert Road Racer
59
Rep 1,329
01-10-2007, 11:43 AM | #8 |
The limit of adhesion is my home.
1702
Rep 3,778
used to happen to me too and i solved it by doing the following:
- at start I idle for approx 1 minute to let the oil circulate around the engine - I drive off after but DO NOT go over 3800 rpm until the engine has reached near normal operation temp of 210 (200 is fine). The above has worked for me very well. Hope this helps
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
01-10-2007, 12:15 PM | #9 | |
Rep 125
01-11-2007, 01:22 PM | #11 | |
630
Rep 1,649
The car has enough miles and tanks of gas (all 91CA) with the problem there to eliminate low octane or bad gas. Oil temp is not an issue either: 230 and it will still do it. |
01-12-2007, 03:11 AM | #14 | |
Rep 79
Dont buy gas from no-name stations. Only use Chevron, Shell, 76, etc. Not saying this will fix the problem, but every turbo owner should use higher quality gas. |
01-12-2007, 09:57 AM | #16 | |
Rep 125
Try it. |
01-12-2007, 11:15 AM | #18 | |
Rep 125
01-12-2007, 11:28 AM | #19 |
Rep 153
I believe I read someone else stopped the valve from closing in the "Under the Hood (NA-Engine) / Drivetrain / Exhaust Modifications
Everything engine and drivetrain related" forum area and they said the car's performance deteriorated. Explaination was the closing of the exhaust increased torque at lower levels. Replacing the exhaust system shouldn't be a problem, but anyone looking to just stop the valve from closing may have a problem Disclaimer: I know NOTHING about this stuff. Only trying to reiterate what I read on another post. People with more knowledge, feel free to chime in. |
01-12-2007, 11:31 AM | #20 | |
Rep 125
