2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes F10 tire / rim offsets
      09-02-2010, 02:53 AM   #1
vngooi
Drives: F10
Hi all,
Any Brothers able to advise on what are the correct offsets for the F10 in sizes of 18,19,20 inches tyres - without resorting to the use of spacers?
Thanks much.
(BTW, are the 7-series original 18in rims and tyres able to fit the F10 without spacers?)
      09-02-2010, 04:01 AM   #2
78mao
78mao's Avatar
Taiwan
133
Drives: F10, F13, current->F80, F15 X5
2015 M3 BMW M3  [1.00]
yes please! this info would really help on advising what offsets to order when getting wheels!!
      09-02-2010, 04:10 AM   #3
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
2011 F10 528i  [10.00]
+1
      09-02-2010, 04:34 AM   #4
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Here's the F10 OEM wheel sizes and offsets.
17x8 and 18x8: ET30
19x8.5 and 20x8.5: ET33
18x9, 19x9 and 20x9: ET44
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      09-02-2010, 04:39 AM   #5
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
Thanks, Remmib.
Any idea on 19x10?
      09-02-2010, 09:58 PM   #6
vngooi
Drives: F10
Most appreciated Remmib!!
Great community..!!!
      08-02-2018, 08:58 AM   #7
keeyu
Drives: 528i
How about the stock tire sizes?
      08-02-2018, 02:13 PM   #8
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
245/45-18, 275/40-18
245/40-19, 275/35-19
245/35-20, 275/30-20
      08-31-2018, 01:27 PM   #9
TEF
111
Drives: 16 X3 28d/18 540d xdrive
2018 540d xdrive  [0.00]
2016 X3 28d  [0.00]
Relative to wheels for the F10, I currently have 19" wheels (style 356) on my '16 535d xdrive. Since I am not a huge fan of large rims and RF tires, I am thinking of replacing my wheels and tires with 17" wheels (Style 327) and the appropriate-sized non RF tires in the future. While it appears that F10's were sold with 17", 18" and 19" wheels depending on engine and trim levels, is there any clearance reasons that the 17" wheels would not fit my F10? For example, were there any mid-production changes to brake rotor and calipers size that might interfere with the smaller diameter wheels?
I realize that going to smaller rims and narrower tires is contrary to the typical wheel/tire upgrade, but I see no reason to pay more for 19" tires when the smaller diameter wheels and tires ride smoother and are much lighter. Moreover, winters in my area result in wheel-busting potholes that do not work well with 19" and 20" rims.
The smaller 17" wheels are plentiful, but I don't want to purchase a set without some certainty they'll fit. So thanks in advance for any input on the matter.
      09-01-2018, 10:56 AM   #10
remmib
remmib's Avatar
Norway
1568
Only the 550i needed 18", the rest fits 17".
      09-01-2018, 08:40 PM   #11
TEF
111
2016 X3 28d  [0.00]
Thanks. I suspected that was the case, but you've confirmed it.
      09-24-2018, 10:28 PM   #12
lashal
Drives: BMW F10 535i 2012
(Wheelarch trim)small part
Anybody know where should i get the little part of wheelarch trim for my BMW F10 535i 2012. There is small plasti on the left side number 9 on this link !
https://www.etkbmw.com/bmw/images_etk/B0072482.jpg
Thanks guys !
      09-24-2018, 11:35 PM   #13
wcr3d
Drives: 2013 535i XDrive M Sport
You should start your own new thread.
Get the part number and Google it.
      10-05-2018, 07:50 PM   #14
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
Thanks guys !
Just and FYI in regards to the part database and diagrams...the encircled numbers indicate HARDWARE. As you can see in the diagram you posted...all of the encircled numbers (like #9) have there own key within the illustration. You can see #9 is a push pin...and this would also be revealed if you scrolled down to the part number index BELOW the diagram.
And as wcr3d suggested...it's easy to find parts once you have their 11 digit BMW part number. You can either call or stop by your local BMW dealers Parts Dept (not the service dept) and get a price quote as well as see if they have it in stock or need to order it. And you can simply type "BMW xx xx x xxx xxx" (where x=the actual BMW part number) into a google/internet search box and it should pull vendors that sell the part online. Unless it is a very rare and specific F10 part...there are usually a good list of the regular online vendors that will have the part available.
Good luck.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
5post
