Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Break in oil
      09-11-2005, 02:31 AM   #1
CA330i
Drives: E90 330i
Break in oil
It is my understanding that synthetic oil is insuffecient (too slick) to proberly seal the rings for break in. I will acquire my 330i at the end of the month, and intend to immediately replace the synthetic oil with dino oil to facilitate proper break in. To me, this seems like a no-brainer, and I am surprised that this has not been brought up before. Am I missing something? Please advise.
E90 330i Ti Grey Burl/ZSP/ZPP/Navi/PDC Manual
      09-11-2005, 02:33 AM   #2
Oz
Oz's Avatar
Drives: 2006 330i, 2004 X5
2006 330i  [0.00]
Actually, this has been discussed a lot here recently. I just passed the break in period last week (currently 1360 miles) and I don't plan to change it until my next service
And I'd rather not do the first oil change myself. I worry that I might mess something up. How much does the dealer charges for a wanted oil change?
2006 330i Steptronic/Alpine White/Black Leather/Burl Walnut Trim/Premium Package/iDrive/Heated Seats/Winter: STYLE 159 Blizzak LM-22 RFT/Summer: TBD
2004 X5 Steptronic/Alpine White/Grey Leather/Poplar Trim/Premium Package/Heated Seats/iPod Adapter
      09-11-2005, 02:34 AM   #3
HRC
MAUI BUILT
HRC's Avatar
Drives: 2006 330i MT
2002 E46 325i  [0.00]
2012 E70 35i  [0.00]
BMW has designed this engine to run on synthetic, not like the engines we are used to. I would leave it in, dino oil will ruin your car!
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
      09-11-2005, 02:43 AM   #4
CA330i
Drives: E90 330i
Hi OZ, thanks for the reply. I don't believe that the issue of whether or not synthetic oil is suffecient for break in as opposed to dino oil has ever been discussed here. There has been plenty of discussion regarding when to change the synthetic oil though. To me that is clear... 1200 miles to flush out shavings etc.. My question concerns the initial (and all important) <50 miles when the piston rings seal. It has always been my understanding that dino oil is superior to synthetic in that regard when it comes to sealing the rings. I would appreciate any thoughts on dino v. synthetic during the short but vital break in period.
      09-11-2005, 02:54 AM   #5
CA330i
Drives: E90 330i
HRC - thank you for your reply. I appreciate your comments, but to say that BMW has designed the engine to run on synthetic oil without data as to how, concerns me. The rings still need to seal. The slippery nature of synthetic still concerns me. Unless they figured out a way for the rings to seal adequately with syn as opposed to dino then I am still concerned. Dino oil is superior to synthetic for break in. Am I mistakin'?
      09-11-2005, 04:08 AM   #6
E90Fleet
South Africa
1312
Drives: BMW
The tolerances to which these engines are built means they dont need break-in oil.
We tested a E46 at a tuner before work was carried out on it. The car had normal BMW paid services at the stipulated intervals and had over 100,000Km on it, and we tested the compression in each cylinder. The compression was perfectly within factory spec for each cylinder
So the rings were perfectly seated with the normal oil.
With the older engine building technology and tolerances one had to run mineral oil because it took quite a while for the rings to seat, but has not been the case for BMW engines for quite a while now
      09-11-2005, 04:10 AM   #7
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
Please tell me or better still us what the difference is between the 2 oils. How is the Dino oil better for break in period better than synth oil and why do you believe BMW doesn't use it at all?
I have owned BMWs from new since 1992 without any break in or further problems using BMW's oil. This issue you have just brought up interests me if what you understand from Dino oil holds true.
Are there conclusive tests carried out on cars to show that Dino oil is better? What about long term use of Dino oil?
I await further information with much anticipation. Thanks very much.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      09-17-2005, 08:52 PM   #8
n21k
n21k's Avatar
Drives: E90 325i
2005 E90 325i  [0.00]
1999 E46 320i  [0.00]
What engine oil do you use? My friend recommended Torco racing oil(SAE 10w-30), anyone using?
I'm planning to change my engine oil after the break in period, can someone recommend the right engine oil besides Castrol which BMW recommends.
      09-19-2005, 01:10 AM   #9
romeo26
44
Drives: e30 325 (no lette)
i thought it was 0w-40??? or some thing close to that!!
      09-25-2005, 06:29 PM   #10
n21k
n21k's Avatar
Drives: E90 325i
That's was what my friend used on his E46 and claims very smooth. Not sure if Torco Racing oil comes in 0w-40.
But most lightly, I will stick to Mobil 1 since is LL01 or/and recommended by most BMW mechanic, especially for me since I'm not using my E90 for track or race.
