"2nd generation" motor coming for 335i already??
01-13-2007, 03:27 PM | #1 |
your average JAMF
3094
Rep 4,092
Drives: '21 M2 Comp, '19 Golf R
From the new issue of Autoweek that just arrived, describing the refreshed 5-series that's about to show up as an '08 model...
...all-new inline six-cylinder engines-the turbo model fitted with the German carmaker's second-generation High Precision direct injection fuel system. The updated engines, which head into other BMW models throughout 2007, don't offer any great increase in power or torque but are more economical and emit lower levels of cardon dioxide than their predecessors. Maybe I'm reading too much between the lines, but "2nd generation" direct injection? Does this not sound like something new already?
'21 M2 Comp
'19 Golf R |
01-13-2007, 03:37 PM | #5 |
Rep 8,338
i'm getting kind of pissed off w/ bmws marketing strategies /rant
01-13-2007, 03:40 PM | #6 |
Eight Bimmers and counting
35
Rep 761
I've been reading some of the service training literature from the engine and forced induction thread. Our cars have second-generation Direct Injection. First generation was the 2003 760Li.
2014 F10 M5
Previously... Threes: '08 E90 M3, '07 E92 335i, Fives: '11 F10 550i, '02 E39 M5, '00 E39 540i/6, '97 E39 528i, '92 E34 525i Others: VW, MBz, Peugeot, Toyota, Olds |
01-13-2007, 04:12 PM | #8 | |
Rep 4,172
01-13-2007, 04:12 PM | #9 |
Rep 5,389
The '07 335i's N52 engine is a 'direct injection' tt engine.
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | |
01-13-2007, 04:16 PM | #10 | |
Rep 1,013
Paul
01-13-2007, 05:14 PM | #11 | |
Rep 1,096
This "[i]...all-new inline six-cylinder engines-the turbo model fitted with the German carmaker's second-generation High Precision direct injection fuel system" ... is what's in the 2007 BMW E90/91/92/93 335i. No need to start Hyperventilating. |
01-13-2007, 07:05 PM | #12 | |
Rep 748
-Brett
01-13-2007, 10:07 PM | #13 |
Rep 985
Drives: 08 M5 Sapphire Black
I have question then regarding the turbo gains
If the 2nd gen DI 3.0 liter I-6 gets 273hp then how come the addition of 2 turbos only give it only another 27hp? Does the NA 3 liter I-6 still get valvetronic in addition to getting the 2nd gen DI? I think Audi is going there with their 3.1 liter V6. With DI they got 255hp and they're adding something similar to valvetronic to get 300hp all NA. BMW claimed that valvetronic + DI did not add up to cumulative gains. Some of the gains were redundant.
CZ |
01-13-2007, 10:32 PM | #14 | |
Rep 42
Drives: 07 335i e90 ZSP,ZPP,CA,MB
01-14-2007, 12:21 AM | #15 |
Certified BMW Tech
Rep 22
Ok, the 330 motor is the N52 guys, and the 335 is the N54.
The 335 and the 760 are the only gasoline powered DI BMW engines (not getting into the new NEW MINI). The N52 and others are not DI because they do not inject fuel "DIRECTLY" into the combustion chamber as do the 335 and 760 "DIRECT INJECTION" motors do. As far as the training I have recieved, Valvetronic is used to "reduce pumping losses," From the vacuum caused on the back side of the throttle bodys on non-Valvetronic engines. Since the N54 has a turbo that also does the same thing (it actually has pressure forcing air into the cyl. instead of placing a the intake under a vacuum). This is why valvetronic + DI are not redundant, and the 760 uses valvetronic + DI and the 335 does not. |
01-14-2007, 03:17 AM | #16 |
Rep 1,238
760i engine = 1st Generation DI
ALL current and at least near future 335i and soon to be 535i = 2nd Generation DI The N54 engine does not have valvetronic. Maybe BMW will incorporate that in sometime in the future? The N53 engines, not available in North America, are not forced induction engines. They are 2nd Gen DI I6 engines capable of lean burn mode. This is speculated to be available in the US when low sulphur gasoline is available. |
01-14-2007, 05:42 AM | #17 | |
Rep 579
Instagram: te37sl_m3
01-14-2007, 06:43 AM | #18 | |
Rep 1,035
Valvetronic will come in time. It's benefit on a second-generation DI engine is debatable (if the engine already has a lean-burn mode, you're not going to gain too much more efficiency by adding valvetronic), but I'm sure we'll see it in the future. |
01-14-2007, 08:37 AM | #20 | |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
01-14-2007, 10:44 AM | #21 |
Rep 563
The current 2nd generstion DI in the 335 does not have "lean burn". Maybe this is what the article is reffering to. I guess they just have to recode the ECU to do that. Only question is, is the US gasoline moving to low sulphur as the diesels. I was checking the EPA website but found nothing.
01-14-2007, 12:25 PM | #22 | |
Rep 710
