GIAC Stage 2 Hardware Requirements Question
09-15-2010, 08:23 AM | #1 |
Rep 4,249
I understand that the GIAC Stage 2 tune requires some supporting hardware - FMIC, Down Pipes, Exhaust, Intake. My question is, is the intake really required or can I just use a drop in with stage 2? From what I've been reading about intakes it seems that very few flow much better than OEM. I'd like to get the stage 2 tune when I have the rest of the hardware but I really don't want an aftermarket intake if I don't need it. Anyone know what the consequences will be if I just go with a drop-in? Will it give me trouble or just not reach the max power potential by a few ponies? If we're talking the latter I'm fine with that but if it will actually cause problems then certainly I won't do it. And what are we talking here, maybe 10hp that I'd be missing out on, if that? TIA guys!
09-15-2010, 10:03 AM | #2 |
Rep 3,262
In fact, many flow better but few flow better AND cooler...most of them suck hot air and this is felt the most at low-mid RPM when the air flow in the engine bay is low.
09-15-2010, 10:24 AM | #3 | |
147
Rep 1,103
09-15-2010, 11:37 AM | #5 |
17
Rep 310
its been proven that the "hot air" dci's help a lot more then they hurt. the turbos do not produce as much heat with the less restrictive dci, so you actually make more power even though your sucking in engine bay air.
09-15-2010, 11:47 AM | #6 |
Rep 7,377
+1 the turbos need to breath freely. An intake has to be used with Stage 2 because of the high boost achieved. To get more air they will spin faster creating more heat. Injen is a good looking intake IMHO.
09-15-2010, 12:12 PM | #7 |
200
Rep 1,741
Drives: e92 335 space gray/coral red
I am running a Stett CAI with stage 1 - just waiting for the the stage 2 flash to get finalized with the flashloader (map switcher). The intake sits in front of the driver's side wheel and if you cut away the plastic shield behind the mesh in the front bumper you are essentially force feeding cold air directly into the intake. Don't drive through deep puddles or standing water, though!
Do you not like the look of the DCI or CAI? I like the way my CAI looks, just black piping in the engine bay, not flashy or noticeable at all
GIAC S2 | Brembo GT BBK 355/345 | BBS CH-R | Michelin Pilot Super Sports | AR Design: DP, S1 Oil Cooler, OCC | AMS FMIC | Bastuck Quad Exhaust | Borla MP | KW V1 | Stett: CAI, CP | Forge DV | P3 Boost Gauge | Arkym: Front Lip, Rear Quad Diffuser | Vorsteiner CSL Trunk | LUX H8 | ModMyNav | MFD M3 Sideskirts | BMW M-Tech Front/Rear Bumpers, Edition Grills |
09-15-2010, 12:52 PM | #8 |
Rep 4,249
It's not that I don't like the look, but an intake just screams "I'm modified" to the dealer when they pop the hood and I'm not at all interested in swapping it out every time I go in for warranty or maintenance service. I'd really like to keep the engine compartment as stock looking as possible.
Also, I really don't understand how the OEM intake is worse than an under hood DCI. The OEM intake gets cold air but a DCI doesn't. So why won't a decent drop in work? Does OEM really flow that much worse than a hot-air DCI? |
09-15-2010, 12:55 PM | #9 |
Rep 4,249
I also don't understand why an intake like Dinan doesn't use the snorkle in front that the OEM intake uses. Is that not getting cold air? Why must it be routed down low?
09-15-2010, 12:59 PM | #10 | |
Rep 669
09-15-2010, 01:08 PM | #11 | |
Rep 3,262
I gained 4whp with my Helene drop-in, over the stock filter. Dinan claims 5 extra hp with their intake on a completely stock car, which means the stock intake is restrictive. However, since the stock intake can accomodate the 13-14psi overboost in the 335is, it is another reason to believe that a drop-in filter may work with the 16psi GIAC Stage 2.
09-15-2010, 01:14 PM | #12 |
Rep 3,622
The Dinan intake still uses the stock snorkle. It adds a new lid, with an additional cold air snorkle. It is the ideal intake, some company just needs to make a cheaper noncarbon version.
09-15-2010, 01:15 PM | #13 |
Rep 7,377
The Dinan is a great intake that will flow probably enough since it draws air from 2 sides. Expensive but definetely very well looking and engineered.
09-15-2010, 01:25 PM | #14 |
Rep 231
Dinan DOES use the existing intake track, but also uses a CAI type snorkle w/ filter routed down low. It basically is a new top and CAI for the stock set up. It's a really nice set up, but a little pricey for most.
09-15-2010, 01:50 PM | #16 | |
26
Rep 372
09-15-2010, 01:55 PM | #17 | |
26
Rep 372
09-15-2010, 01:58 PM | #18 | |
Rep 3,622
09-15-2010, 02:36 PM | #19 | |
26
Rep 372
For what it's worth, some of our testers used the stock exhaust and simply removed the secondary cats with good success. |
09-15-2010, 02:43 PM | #20 |
151
Rep 1,677
My understanding from previous PMs with Austin is that stage 2 (not 2+) absolutely requires an FMIC and downpipes. Second cat delete, exhaust and intake are recommended (for more gains) but are not necessary.
I don't know if these requirements and recommendations have changed. They might be putting together an official document right now before release. Who knows? If not, might be a good idea. |
09-15-2010, 02:48 PM | #21 |
Rep 4,249
You guys are good - now I'm understanding...
I didn't realize Dinan used both - that makes a lot more sense. So Austin, regarding the cats..., I have an AE catless exhaust right now and I'd rather run cats instead of a DP fix. So are you saying I'd be better off getting a set of high-flow catted DPs instead of cats down further in the system? I was thinking the opposite and was planning to get AE high-flow cats, add them into my exhaust, and go with catless DPs. The problem here is that AE no longer sells the high-flow cats so if I'm good to go with catted DPs that would be great. Also, am I correct in assuming that if I go with catted DPs (thinking of Macht Schnell or AR) I won't need the DP fix? Thanks again, guys! |
09-15-2010, 02:49 PM | #22 |
Rep 3,622
Thanks, that was my next question. So basically a fully catless setup is recommended with stage 2, whether it be secondary cat delete, catless midpipe, or aftermarket exhaust.
