RF p300-2 Amp setting questions
09-16-2010, 10:20 PM | #1 |
Rep 587
I just finish installing the RF P300-2 AMP and a set of SWS 8xi Speakers. although i feel i am capable for installing this equipment I have no idea when it comes to setting it up to sound good. here are my questions.
1) What Frequency do i set it to? 2) What Gain setting should i run? 3) What setting do i set my L7 to or does this matter? also when I'm adjusting the frequency and gain i notice the screws to adjust do 1/2 rotation past the min or max setting. for example i see the indicator marker when i turn it fully counter clockwise, the "dot/indicator" does not point to the Minimum setting but rolls past it for about half a turn same goes for the Max setting. is this normal? Sorry if this is a stupid question. Thanks, Jorge |
09-17-2010, 05:11 AM | #2 | |
2306
Rep 13,010
If that's not satisfactory to you then increase the P300-2 gain to your taste. |
09-17-2010, 07:19 AM | #4 | |
2306
Rep 13,010
Page 4 = AP You can also play with the Punch EQ adjustment and the filter in LP at 340Hz, gain at 1. |
09-17-2010, 11:51 AM | #5 |
Rep 587
very cool. thank you! BTW your harness was the easiest part of my install. great product. I have one final question and i already know the answer but i just wanted to confirm. I notice that as soon as i open my door or unlock the car the amp turns on. also when i lock the door it takes a minute or so to turn off. I'm guessing this is normal but I just wanted to make sure.
Again thank you for your help with my install. Jorge |
