Guys whit Stg3+meth how much boost?
09-18-2010, 05:02 PM | #2 |
Rep 6,631
depends on the amount of meth you are spraying and what type of ign timing you are getting at the boost level. I can go up to about 18psi on a CM10 nozzle before my timing drops below 10 degrees.
fyi, i'm a stg 2.75 stock midpipes and exhaust.
E90 LCI N54 6AT
09-18-2010, 05:29 PM | #3 |
Joint Chiefs of Staff
4920
Rep 115,999
I am at about <17PSI (In the 16s) with a dual CM7 and CM5 nozzle setup.
Here is a dyno I recently did at about 16.5PSI with the above setup running a 90/10 mix with pump gas (94 octane). Timing is perfect. I can push more boost, but I find this to be the sweet spot. Mike P.S I should note I have all stage 3 mods, except for the stock exhaust with stock mid cats. Last edited by Mike@N54Tuning.com; 09-18-2010 at 11:04 PM.. |
09-18-2010, 07:13 PM | #4 |
Rep 6,631
Mike - same setup as me with less boost. I need to dyno and compare to your results.
Edit - I run a single cm10 instead of the dual nozzles though.
E90 LCI N54 6AT
09-18-2010, 08:52 PM | #6 |
ElevenPointFive
326
Rep 2,450
Daily driving with 94 octane pump gas with 70/30 meth, I run 16.5psi tapering down to 15psi in 3rd gear. Full stage 3 mods running JB3 map 7 with meth map 8 enabled. Log below of a 3rd gear pull.
On the track I run 19.5psi tapering to 17psi running 90/10 meth mix on JB3 map 11.
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
09-18-2010, 10:33 PM | #7 |
Rep 6,631
Wow, looks like I'm pushing more boost than everyone else. I'm running 100% meth
When I get the car to the dyno I will be sure to try the high and low boost settings. For me, my timing is +10 degrees or better on 17.5 target with CM10, so if it ain't broke don't fix it I guess. Take a look at that log. 10+ degrees at boost even higher than 17.5; bet others could do the same easily. Procede progressive meth is an amazing failsafe as well.
E90 LCI N54 6AT
09-18-2010, 10:37 PM | #8 |
ElevenPointFive
326
Rep 2,450
Very nice looking log myst, your boost and timing are gorgeous.
09-18-2010, 10:38 PM | #9 |
Rep 3,730
I hold 17.5 psi with my M7 nozzle and 100% meth, i'll post some logs in my Aquamist review once I get my car back from the dealer (3rd HPFP and counting).
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
09-18-2010, 10:47 PM | #10 |
Rep 6,631
I think I could probably up the boost a bit more to say 18 on 93+meth, but it'll hurt timing I think. Guess I need to log that and see how it does....
E90 LCI N54 6AT
09-19-2010, 04:07 AM | #12 |
Rep 1,054
just got map 9 timing up over 10 with 93 + 95/5 meth/blue windshield fluid. cm 7 and cm 5 in a silicone elbow. Boost from 17-18
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
