Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > Meguiar's PlastX - Can I get better results?
      09-19-2010, 04:13 PM   #1
MaximusJ
MaximusJ's Avatar
303
Drives: 340Xi MG 2017
Hi there,
Just tried to clean my girlfriend's civic headlights by using Meguiar's PlastX and i'm not that satisfied with the results. A lot of people vouch for that product and say it can turn a used opaque headlight to a brand new one. But I'll show you what I was able to do and would like your comments to see if I can get clearer then that.
This is the "before" picture.
Attachment 432198
This is the "after" picture.
Attachment 432199
On the left one, I tried applying multiple layers of the product and couldnt get better results then the right headlight. But didnt get better results.
Attachment 432200
I've applied the product on a sponge and rubbing the sponge on the headlight; like suggested on the bottle. Any leftover was remove with a microfiber towel.
I just saw on google that some people use meguiar's powerball and get good results, but they are doing it on headlights that are not as bad as mine so... I would like to know your point before buying that thing that I'll probably never use again.
Thanks for your input.
      09-19-2010, 04:15 PM   #2
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
did u try using a rotary
      09-19-2010, 04:18 PM   #3
MaximusJ
MaximusJ's Avatar
303
Nop; I have an PC tho; just wanted to be sure it can be done prior to mess her headlights with the buffer.
It wouldnt be too rough for plastic? If so; what kind of pad would you use?
Mineral Grey '17 F30 340XI
[Garage] // [Build Journal]
Jet Black '06 E90 325I
[Garage]
      09-20-2010, 02:11 AM   #4
Houman21
Houman21's Avatar
Drives: Nothin right now
I've used this
Works well, all you need is a drill - corded is better here.
2008 e92 335i Step | Is Gone - It was fun but not meant to be | M3 - Cancelled | 135 Ordered
      09-20-2010, 08:02 AM   #5
Krells
Drives: 07 335i
Originally Posted by Houman21 View Post
I've used this
I second the 3M kit. I was able to get much better results with it than I did using plastic-x. Should be able to get it at Autozone too.
      09-20-2010, 02:09 PM   #6
TheRox
TheRox's Avatar
119
Drives: 6mt
you need to use a power buffer
hand will get you exactly that result, not bad,,...know a guy with an s2000....has similar results by hand.
      09-20-2010, 08:20 PM   #7
zeenon53
zeenon53's Avatar
39
Drives: BMW
Go from your course to smooth with your PC pads. The lenses are very thick and hard to mess up.
      09-21-2010, 07:57 AM   #8
MetsFan
MetsFan's Avatar
92
Drives: 2013 G37x
2007 BMW 328xi  [0.00]
I agree with those that posted the 3M kit. It helped clear up the yellowing and peeling UV coating on my '02 Jetta. Not perfect, but 100 times better.
      09-21-2010, 11:00 AM   #9
MaximusJ
MaximusJ's Avatar
303
I dont have an autozone shop for miles and miles (I'm in Canada). But I've just found a shop that have that product.
Thanks guys; will keep you posted with results.
[Garage]
