ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Track / Autocross / Dragstrip / Driving Techniques
  TireRack
      09-22-2010, 05:45 PM   #1
schwank
Drives: 06 z4 m coupe
17's on an M?
Hi guys.
Ive been doing 2-3 events a year for the last 4 years. I started out with stock tires/sizes, then went to the Dunlop Direzza Star spec z1's (245/265). The Dunlops are nearing the end of their life, and I am now wondering if I should buy another set in the same size, or if I should buy some light weight 17's for the track.
Has anyone done this?
What are the advantages and disadvantages? (other than weight savings, and less cost per tire)
I do run track pads (Hawk HT10's) and I have KW V3 suspension. And I generally run in B group.
Thanks!
      09-23-2010, 06:02 PM   #2
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
Drives: 2006 Z4MC Interlagos
Not many 17's have the offsets without spacers to clear our brakes. Stick with 18's on a set of lighter track wheels...
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
      09-24-2010, 10:03 AM   #3
Trev
Drives: Z4MC
Like he said with 17" offset's are your biggest problem. However for any custom wheel shop it shouldn't be difficult for them to deal with it.
Pro: Aside from weight, cheaper & more choice of tyres.
Pro: You can reduce wheel circumference which will increase your acceleration but reduce your top speed in each gear.
Con: Will your front brakes fit?
Con: If you stagger 18" on front & 17" on rear you'll create a nose up stance, which will need a coilover height adjustment & maybe even an alignment.
      09-24-2010, 12:30 PM   #4
silversprint
Drives: Z4M
17" SSR competition Type C wheels fit. I have had them on my Z4M.
It's not reallythe offset that needs to clear. It's more the clearance inside the barrel and the spoke design. Some of the cheaper made wheels have a lot more metal on the inside and will not clear the brakes.
MR-S Track -2100lbs/300hp
Miata
Z4M Coupe (Sold)
      09-24-2010, 01:14 PM   #5
Thisisdudewhoru
Thisisdudewhoru's Avatar
Drives: 16 BSM 340i
I wonder if z3M wheels will fit?
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
      01-23-2014, 02:48 PM   #6
drsasha
Israel
Drives: Z3mc , Z4mc
Sorry to bump this, but did anyone try the z3m roadstars on his z4m??
      01-23-2014, 02:59 PM   #7
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
I have a ... just one ... Z3 M Rim from my previous Z3 that I could fit a 245 tire that I have laying around on and mount it to the Z4MC. I haven't brought it to a shop but I've been meaning to (just so I have a spare that I could throw on the rear for a short period of time).
I'll let you know if this happens.
There is a member however that did throw 17s on his Z4MC.
Found here:
http://www.zpost.com/forums/showthre...5#post15314805
      01-23-2014, 04:50 PM   #8
drsasha
Israel
Drives: Z3mc , Z4mc
Please do. Did you test fit rear I'm front one?
      01-23-2014, 09:17 PM   #9
z3papa
Drives: 11 E92 M3 ZCP, 07 335i
I would be utterly stunned if rear Z3M wheels worked since they have a ridiculously low offset.
Sold 2011.5 E92 M3 ZCP.
      01-23-2014, 11:21 PM   #10
drsasha
Israel
Drives: Z3mc , Z4mc
Fast calculation show that rear will extend out 22mm.
Like a 20 mm spacer on the back.
Not that crazy
      02-06-2014, 01:51 AM   #11
kvnchu
Drives: z4m
colatkitty successfully ran 17's Apex Wheels
http://www.zpost.com/forums/showthread.php?t=816376
Fronts need +12 spacer
Currently Driving:
Porsche GT4 '20
BMW M2C '19
Caterham S3 '01
Porsche 993 '96
zpost
