ZPOST
  TireRack
      09-25-2010, 03:39 PM   #1
mhrir
Drives: Very fast
Track pad brake wear
I have completed 4 DE events on a set of Raybestos ST43 front pads on my Z4M Coupe. I have noticed that the pads have been wearing unusually - at an angle. Stock calipers and rotors. Anyone have any experience if this is normal? Or should I be concerned?
Right Front:
Left Front:
You can see that the backing plates are parallel to each other and the pad material is worn at an angle.
      09-25-2010, 07:20 PM   #2
jmillet
jmillet's Avatar
63
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Right Front:
Left Front:
I experienced a similar wear pattern running ST-43 pads on my former E36/8 Z3 M Coupe. I removed the inside pad piston clips and the wear evened out. I'm running PF-01 pads on my Z4MC and the wear pattern is more uniform. The PF-01 does not have an inside piston retainer clip.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      09-25-2010, 07:35 PM   #3
silversprint
Drives: Z4M
normal wear for single piston caliper.
MR-S Track -2100lbs/300hp
Miata
Z4M Coupe (Sold)
      09-26-2010, 12:04 AM   #4
mhrir
Drives: Very fast
Good to know. I was used to the pad wear with my Cayman.
Any explanation of how it wears at an angle?
      09-26-2010, 03:19 AM   #5
johanness
56
Drives: 2008 Z4MC
we have single piston calipers?
      09-26-2010, 12:35 PM   #6
jmillet
jmillet's Avatar
63
No need to cry over single piston calipers on the E86 Z4MC as we have the Competition Package brakes off of the E46 M3. With proper brake pads these brakes are more than adequate for HPDS events. I use the PF-01 pad for my track events.
Jim Millet
      09-26-2010, 09:32 PM   #7
johanness
56
Drives: 2008 Z4MC
^^^Thx Jim.
I know that these brakes feel fantastic and have some premium stopping power. Good to know
      09-27-2010, 08:08 AM   #8
lucid
lucid's Avatar
Drives: E30 M3; Expedition
OEM caliper guides are rubber and result in significant play under heavy braking. You can replace them with solid ones, but then you need to make sure they are lubricated on a regular basis or they might get stuck.
Bimmerworld has the solid guides on sale. See pics on their site for the OEM and solid guides.
http://store.bimmerworld.com/categor...guide&x=37&y=6
      09-29-2010, 01:34 PM   #9
mhrir
Drives: Very fast
Sounds like I need these. What lubricant is best?
      09-29-2010, 05:27 PM   #10
R32
Drives:
these are indeed the solution. you will also get a firmer brake pedal with these. the lubricant is synthetic brake caliper grease.
      09-29-2010, 07:55 PM   #11
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
192
Drives: '01 911 Turbo
Originally Posted by jmillet View Post
No need to cry over single piston calipers on the E86 Z4MC as we have the Competition Package brakes off of the E46 M3 CSL. With proper brake pads these brakes are more than adequate for HPDS events. I use the PF-01 pad for my track events.
^ edited
btw, wouldn't it not hurt to also do lines and fluid? I was thinking StopTech lines and ATE Super Blue for just amateur HPDE learning events
I used Goodridge SS lines and ATE Super Blue on my MR2 for my 4 and only track weekends with success.
      09-30-2010, 08:59 AM   #12
lucid
lucid's Avatar
Also, swapping front pads only is not the best approach. If the pads you are swapping in are more aggressive than the OEM pads (higher overall CoF values), you'll shift your brake bias more forward, and the rears will do less work. Your front brakes/tires will heat up more (the differences are measurable), and you won't be utilizing the traction available in the rear. That is not the end of the world, but I'd do all 4 corners--especially if you start seeing very high temps on the front rotors.
      09-30-2010, 03:30 PM   #13
JCz04Bimmer
JCz04Bimmer's Avatar
30
Drives: 06 Z4MC
Very true. I ran Ferodo DS3000's (Track Pad) in the front and the DS2500's (Aggressive Street Pad) and observed front rotor temps around 920deg and rear rotor temps around 580deg. Needless to say, I immediately purchased a set of Hawk HT-10's and now get around 650deg front and rear consistently.
|www.onehotlap.com|Real People|Real Cars|
zpost
