10-02-2010, 07:32 PM | #1 |
138
Rep 2,042
BMW performance Brakes for only $845!
United BMW are having a sale atm for sets of front and rear brakes for the 135i. You get all this:
6piston phoenix yellow front calipers w/ pads 2piston phoenix yellow rear calipers w/ pads front brake sensor, rear brake sensor front BMW Performance slotted/drilled rotors rear oem vented rotors So I was thinking if the fronts alone will fit the fronts on the Z4 this will be a BARGAIN for $845+shipping. I know Brembo haven't tested it for the e89 etc etc... Will they fit without modification?? |
10-03-2010, 02:15 AM | #2 |
Rep 695
Drives: 2021 M2 Competition
Garage List 2014 Porsche C4S Coupe [0.00]
2019 330ix Sportwagon [0.00] 2014 Jaguar F-Type ... [0.00] 2021 M2 Competition [0.00] |
Actually it seems shipping is free in the lower 48.
BMW Performance Brake Kit (Complete), (2008-2011 1 Series) The BMW Performance braking system is designed to facilitate a sporty driving style. The six-piston aluminium fixed callipers and grooved, cross-drilled discs give drivers an incredible amount of control, even in the wet, while their low weight reduces the unsprung mass of the car. Calipers painted in BMW Performance Yellow are a striking visual feature. 135i includes: * 6 Piston Front Calipers with brake pads and wear sensor * BMW Performance Front Slotted & Cross drilled Rotors * 2 Piston Rear Calipers with brake pads and wear sensor * Genuine BMW factory rear rotors 128i includes: * 6 Piston Front Calipers with brake pads and wear sensor * Brake Dust shields * BMW Performance Front slotted and cross drilled rotors * Genuine BMW 1 Piston factory rear calipers with brake pads and wear sensor * Genuine BMW factory rear rotors Free ground shipping to the lower 48 States is included in the price. |
10-03-2010, 03:22 AM | #4 |
tuned
524
Rep 696
waw... i want.
who can help me out with that to send it for me to austria???
10-03-2010, 03:48 AM | #6 |
tuned
524
Rep 696
can someone post up the email to contact them pls?
10-03-2010, 08:18 AM | #7 |
138
Rep 2,042
info@unitedbmwonline.com is the email.
Here is the thread: http://www.1addicts.com/forums/showthread.php?t=438100 Does anyone know if these will fit??? Im not worried about the rears because at this price it is such a great deal for just the front Brembo-made genuine BMW Performance 6 pistons (I had the same brakes on my 135i and they were excellent) + drilled/slotted rotors. |
10-06-2010, 11:17 AM | #10 |
Rep 695
Are you sure? They seem to fit on the 23i. Look here: http://e89.zpost.com/forums/showthread.php?t=317343
10-06-2010, 11:31 AM | #11 | |
Rep 125
e90 will bolt on but 135i, i have check with them, they say it will nt |
11-08-2010, 10:17 AM | #12 |
Rep 433
Drives: Z4 E89
I have this kit installed in my E89 (front only) This is a bolt in installation, no modification needed, CONFIRMED see pictures in my garage If you look at the individual parts carefully, E90 and E87 kits share the same major parts(calipers, pads, discs) , but the kit's part# for E87/88 is 34110443865, for E90 is 34110444738
11-08-2010, 12:00 PM | #13 |
261
Rep 1,499
Drives: 2010 BMW Z4 3.5i 6spd
Guys: many of you have expressed concerns about the electronic ebrake affecting a rear caliper replacement. After meetings with both Brembo and Stoptech the answer is, there is no effect. The mechanism is still the same as a traditional hand brake, except the way the ebrake is engaged is different.
The e70 X5 uses the same electronic ebrake mechanism but we have successfully installed a full front/rear Brembo BBK setup onto the vehicle. The only issue now is which rear bbk will fit the Z4 rear brakes. Tried reverse lookup to see if any of the Z4 rear brake components are used in existing BMW models, no luck. Hope this help clarifies things a little. |
11-10-2010, 07:59 AM | #14 | |
Rep 433
Drives: Z4 E89
01-15-2011, 10:18 AM | #16 | |
In The Flesh
22
Rep 600
01-15-2011, 12:57 PM | #17 |
Rep 1,264
Drives: 2010 Dinan S3 Z4-35i
Yes is this deal still on?
2015 BMW i3 REX
01-15-2011, 12:58 PM | #18 |
tuned
524
Rep 696
01-15-2011, 02:34 PM | #19 |
12
Rep 45
I asked united a few weeks ago and the answer was "no". It is sold out already. I'm sorry I missed this chance. However, you can still buy front brakes only for about $900.
01-15-2011, 09:50 PM | #20 |
Rep 1,264
I found these, different part number since they are for BMW 128 series:
http://www.turnermotorsport.com/html...ANCE-BRAKE-KIT I think they are the same size as the 135, only this comes with the rear rotors too. Price is not bad for a complete set. Just not sure if there is a difference from 135 and 128 kit?
2015 BMW i3 REX
