The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > has anyone replace a oil pan gasket on a e90 ?
      10-12-2010, 11:10 PM   #1
lupelopez1
the king
Drives: 2006 325i sport
      02-27-2012, 02:45 PM   #2
therealm3
630
Drives: F30 340 MSport
I'd like to know also. Mine is leaking....
      02-27-2012, 06:07 PM   #3
whenasked
Drives: E90
Yes as part of CPO..but looks like it is a major repair as lotta things have to be taken apart to get access to oil pan.
      02-27-2012, 06:34 PM   #4
yakev724
yakev724's Avatar
231
Drives: 15 S3
Search, there was a post here by someone who had done it. The front subframe is in the way of removing it completely, but it can be dropped by a few inches, enough to replace the gasket. Not sure what keeps it from sliding out towards the rear of the car, but I guess I'll find out when I go to replace it in the summer.
      03-02-2012, 04:03 PM   #5
therealm3
630
Thanks! I think I found that post. I may try this seeing the cost at shop is crazy. Hopefully there is enough room for my big hands to get in there.
      03-04-2012, 07:41 AM   #6
dapetik
Drives: 2007 335i
I'd also like to see a write-up..... Mine is leaking too
      03-04-2012, 10:10 AM   #7
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
ive done several...its not that difficult but you will need a way to support the engine from the top so the subframe can be dropped...and an angle torque wrench to angle torque all the aluminum bolts..
      04-12-2014, 09:56 AM   #8
Ed_Mitchell
Drives: 2008 335i
I'm searching but havent found a diy for this yet. Anyone have an idea where theres a diy?
      04-12-2014, 11:23 PM   #9
necro24
Drives: 2006 BMW 325i
http://www.e90post.com/forums/showthread.php?t=585855
One found right here
      04-13-2014, 12:50 AM   #10
Makeuwunder
Makeuwunder's Avatar
Alderney
62
Drives: 07 335i
I just did mine on jack stands in my garage. I started off by following this DIY and ended up dropping the sub frame cause my gasket came off in pieces. So I dropped my subframe and just removed the pan. So much easier with subframe dropped and not really that hard.
      05-22-2014, 08:07 PM   #11
techie182
48
Drives: 328i coupe
Any DIY to drop subframe? Mine was leaking but fixed it using Lucas oil stop leak. I'm sure its only temporary so I'll need to change my gasket in the future.
Have shop with all the tools but don't have direction.
      06-12-2014, 03:11 PM   #12
Pr0metheus
Pr0metheus's Avatar
23
Drives: E90 330i
Does anyone else know about these at www.workshop-manuals.com? The instructions are rather vague, but at least I have reference for special tools needed.
Anyone have tips on a place to pick up the tools? I am pretty savvy when it comes to maintenance, but it looks like most guys/gals choose to let a shop or stealership handle this job for them due to it being a PITA without lift & special tools.
Anyone have a favorite shop or stealership they recommend for the job in the bay area (San jose/Fremont zone)? Or better yet someone want to volunteer who has the tools or has done one before?
1) http://workshop-manuals.com/bmw/3_se...n52)/page_260/
2) http://workshop-manuals.com/bmw/3_se...il_sump_(n52)/
3) http://workshop-manuals.com/bmw/3_se...n52)/page_288/
      06-13-2014, 08:47 AM   #13
Glopez5
Glopez5's Avatar
Honduras
18
Drives: E92 335i
What did you use to hold the motor? I'd like to do mine at home and maybe I can make a diy guide.
      06-13-2014, 01:07 PM   #14
Makeuwunder
Alderney
62
Drives: 07 335i
I used a harbor freight engine support bar and the tow hook. Worked out great and was well worth the money. But I also installed new RB turbo's.
      06-13-2014, 08:36 PM   #15
Bavarian Tech
Bavarian Tech's Avatar
267
Drives: 335i
2006 330i  [10.00]
If your RWD, it can be done it 3 hours AWD is alittle bit more involving but still do able.
Some guys leave the subframe and everything still attached with it lowered, and work around it. I find it annoying. I unbolt the arms/tie rods from the knuckles. Unbolt the swaybar end links. Remove the lower bolts the engine mounts. Un-bolt the subframe six bolts. Swing it to the right with the power steering lines and link still hooked up and just work with it to the side. Im sure im missing something but you get the picture
      06-14-2014, 03:52 AM   #16
Pr0metheus
Pr0metheus's Avatar
23
Drives: E90 330i
Tools
Any recommendations for torque wrench or other special tools needed?
I know I need the engine support tool (will be doing mine on jack stands) but am concerned about having a torque wrench small enough to get in there on all of the various bolts for the pan and things I took apart.
      06-15-2014, 06:05 PM   #17
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
I did it w/o removing the subframe, I do not recomend it. Dropping the subframe is a better option.
      06-19-2014, 01:13 PM   #18
Glopez5
Glopez5's Avatar
Honduras
18
Drives: E92 335i
is there anything connected to subframe? other than the motor mount? i've been trying to find pictures but it's hard to tell. Will i need to remove bumper or anything?
I also heard someone removed the subframe and let it hang from the suspension. Any thoughts?
07 E92 335i -BSM- Sport- iDrive- Premium- Cold Weather- Aero Lip- M3 Trunk Lip- Injen Dual Cone- Posi Quiet Ceramic Pads- R1 Premium Cross Drilled Rotors- H&R Sport -JB4+Ethonal- - Raceland DPs - Avant Garde M310- Alpine TypeR 10''- Alpine MRP-M500 Amp
      09-28-2015, 11:33 AM   #19
KrashFinatik
KrashFinatik's Avatar
78
Drives: 2006 325i, Sport Model
With dropping the subframe (6 bolts) and unbolting the angular cross bar (6 bolts) plus engine mounts (2 bolts ea. side) the subframe drops down enough to allow for removal of the oil pan. It will be suspended by the struts.
      10-03-2015, 05:39 PM   #20
KrashFinatik
78
Here you go guys I posted a DIY with dropping the subframe at home in my driveway. I left mine hanging and worked around it. It wasn't that bad of a job and if your mechanically inclined you will definately save money.
http://www.e90post.com/forums/showth...8#post18682558
