Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > How do you take off auto shift knob
      10-15-2010, 04:00 PM   #1
bugsandry
20
Drives: 2008 BMW e92 328xi
I have read the DIY for removing shift knob and most of the discussions are related to pulling off manual shift knob. Any ideas if it's the same thing for auto? Just pull it up straight without pressing the shift button ?
Thank you guys....
      10-15-2010, 05:00 PM   #2
e90TiAg335i
e90TiAg335i's Avatar
Drives: 10 e90 335i
2010 e90 335i  [7.00]
yep, just pull straight up. Don't give yourself a black eye...lol
JB4, DP, VMR V710, Sonic Tuning S1 coilovers, Hybrid Ovations, Soundsplinter 10" and Zapco DC Ref amps
      10-15-2010, 05:41 PM   #3
bugsandry
20
I should not press the shifter right while pulling right? ? just pull it right up when the gear in Park, correct?
      10-15-2010, 07:11 PM   #4
e90TiAg335i
Drives: 10 e90 335i
that's correct
      10-15-2010, 08:39 PM   #5
govtec
Drives: 2006 325xi
You can also put it in N if it works for you. I moved the seat up a little bit and used my elbow as leverage.
      10-16-2010, 03:07 AM   #6
bugsandry
20
Successful..It is easier than I thought. It took me 10 seconds at the most to pull it straight up. Thanks for the help guys....
      10-16-2010, 03:49 PM   #7
Dave4501
Drives: F10, E70, E64, and E60
Do you push the shifter button in while you are pulling up? Or do you not push it in while pulling?
I have tried this technique on my E46 and was never able to pull hard enough. I always felt I would break something.
'12 535i,
'12 X5,
'15 Boxster
RETIRED: '08 650i, '07 530i, '06 330i, '00 323ciC
      10-16-2010, 04:03 PM   #8
e90TiAg335i
Drives: 10 e90 335i
don't worry about the button. My e46 was MUCH harder to remove also. My e90 was easy!
      10-18-2010, 02:30 AM   #9
bugsandry
20
I did not push the shifter button. I did it from the passenger seat following some of the advice in previous postings. 5-10 seconds of pulling up and you're done.
