Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d owners with BT?
      10-24-2010, 01:35 AM   #1
mm335d
Drives: BMW 335d ///M
Hi,
I just wondering is there anyone having stock or modifed 335d and Bavarian Technic Diagnostic Tool? I would like to compare some parameters with my 335d.
For example with my stock 335d:
max. desired boost is 1,759 bar
max. actual boost 2,01 bar
max. engine torque 548 Nm @ 3081 rpm
max. calculated engine torque 614 Nm @ 2272 rpm
absolute pressure in DPF filter 1-1,2 bar
soot mass is DPF filter ~27 g
And these parameters after Evolve reflash:
max. desired boost is 2,01 bar
max. actual boost 2,15 bar
max. engine torque 594 Nm @ 2255 rpm
max. calculated engine torque 650 Nm @ 2255 rpm
DPF filter parameters are the same
So guys what do you think?
For me it's strange why Evolve raises boost only 0,2 bar? Before reflash I had problems with jammed DPF filter, but after manual regeneration things get much better. If anyone have BT and 335d, could you please check absolute pressure and soot mass in your DPF filter? Also what should be stock 335d boost pressure? And what boost do you have after Evolve remap?
Many thanks!
      10-25-2010, 05:17 PM   #2
mm335d
Hmm... Is there any 335d owners who know a little bit more about their cars?
      10-26-2010, 07:59 AM   #3
DieselDiner
DieselDiner's Avatar
486
Drives: 335d
Send a pm to Ron1n, he has a JBD. I don't know if he will have access to the info you're seeking.
A question for you: what oil are you using? I'm curious in the context of your problems with the DPF.
      10-01-2011, 03:26 PM   #4
picoto
Drives: 335d
On your remap, what they did on your DPF? Can you see the miles counter left on the check control?
Thanks
      10-01-2011, 08:48 PM   #5
hotrod2448
grand poobah
hotrod2448's Avatar
Drives: F80 M3, F10 535i
2011 335d  [0.00]
I don't believe the JBD data will be of any use to the OP since it just tricks the ECU into seeing normal values so, the data pulled from the ECU will likely look very similar to a stock vehicle.
OP, there aren't many people in the US running reflashes on their d. You may want to try asking in the european subforum.
Edit: I also just realized most of this thread is a year old.
      10-02-2011, 02:36 AM   #6
hotrod182
hotrod182's Avatar
788
Drives: 2023 i4 M50
I,m pretty sure the JBD doesnt touch the boost levels. Just enrichment.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra,
2008 Black 335i Sedan. 11.11@ 129.47 mph
2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds
2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy)
      10-02-2011, 07:51 AM   #7
cssnms
cssnms's Avatar
Drives: 2011 BMW 335d
true
      10-02-2011, 02:52 PM   #8
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2021 M5 Competition  [0.00]
2016 BMW 550i  [0.00]
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
I can't get my BT to see actual values on anything to save my life. Don't know if I'm doing something wrong, or just not setting it up properly.
JBD doesn't touch boost, because it doesn't hook in to the boost sensor. Some other tunes do for the d, but not the JBD.
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i
      10-02-2011, 03:17 PM   #9
hotrod2448
grand poobah
hotrod2448's Avatar
2011 335d  [0.00]
Originally Posted by Mike@N54Tuning.com View Post
No, the JBD remaps the fuel curve and only slightly increases boost pressure.
Mike
I didn't think about it only altering the rail pressure signal on the d. I agree that the boost data should be correct then with the JBD but, I'm certain as a product of that it is altering boost by some amount as Mike said in the quoted post. Even if it is only the ECU shifting the boost to a value it thinks is acceptable for the fueling it is being tricked into supplying. I am a little curious that I can't find even a ballpark amount of how much anywhere.
