2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Poor radio reception: reverb-like sound and garbled words
      10-29-2010, 02:45 PM   #1
Scargo
Drives: 2010 535xi, 2002 M3 convertibl
On 12-23-09 we took our new 535xi, with M package, to a dealership and had the fuel pump replaced. While there they did a computer update.
The ticket says this:
j# 2 90BMZLC551 program cntrl units, Units: 1.1 Tech(s) :353
sib 12 23 09: Svce action, program cntrl units, DME (OBD)
DC: 00 12 81 02 00...LC: refer to KSD
per service action
Programmed all control units to current software levels per service action
We think this is when the radio reception started sounding poor. On occasion it sound very much like we have reverb or the person speaking is stuttering or words are repeated. Some stations just have static. This is not always happening, but it is often problematic. It does not happen in our other cars.
On 9-17-2010 we had it in to the shop again. They did other repairs and I asked them to look at the radio. They said they could not duplicate the echo (or reverb-like qualities). I believe they did another software update while they had it:
D SIB 13-09-10
Cause: 0059613 SIB 13-09-10 SA N54 Prog Control Units (DME for HDP)
325 WWB
FC: 0013950100
No window tinting was done. No window heating is on. It used to sound fine... Other audio features work fine. Isn't the radio supposed to ignore a station if the quality/reception/signal strength is too low?
Could the work replacing the fuel pump have affected the wiring or connections?
Is any radio antenna wiring involved in a harness that goes to or near the fuel pump?
Any thoughts?
Look at that S car go! Before the M3...
      10-31-2010, 02:53 PM   #2
Touring
Touring's Avatar
Norway
178
Drives: i3,E21,M2,E23, Skoda Kodiaq
Did they try to after-marked tint your windows? I have a friend that did that himselves, ended up with loosing the GPS signal.The antenna is in the window, so he cut it with the knife when fitting the window tint.
I see you lost your window-heater too. Maybe they were a little quick with the knife at the shop, discovered what they did and then removed the plastic-film again?? Is your GPS working?
      10-31-2010, 07:36 PM   #3
dkerr
Drives: '21 X5, '15 X3
I've noticed the same and I think I know why. I am in a fringe reception area and have noticed that the radio will switch from HD (digital) radio to Analog reception, and viz versa, when driving around. During the momentary switch over period voices on the radio can sound hollow or like they are echoing around a big cave or something.
I turned off HDRadio in settings and the problem goes away... to be replaced by the usual analog fade in/out when signal is poor. Try turning off HD in your settings and see if that makes a difference.
You can tell if the radio is receiving HD or analog by looking for the HD symbol in the top right status box in the navigation window (which I normally have visible while driving).
DAK
      10-31-2010, 08:25 PM   #4
lindros2
Drives: 535i M-S
Is this in the right forum?
12-23-2009? The F10 was released in June/July, and the xi just came out in September... 2010...
      11-09-2010, 09:04 AM   #5
Scargo
It is a 2010 xi and we signed the papers on it on 9-21-2009. It already had 5700 miles on it.
      11-09-2010, 09:15 AM   #6
raleedy
Drives: 2016 228i 6-speed
You would do well to post on the E60 board as well since the discussions there apply to the model you have.
      11-13-2010, 09:10 AM   #7
Scargo
Thanks. I'm new to Bimmers... Still don't get why mine was sold as a 2010 and yet is an E-60. Also, how do you know? Because F-10 xi's came out much later?
Turning off the HD did the trick as far as the reverb-like sound quality.
      11-13-2010, 12:15 PM   #8
algoodman
Drives: 2017 540i xdrive
F10's are 2011 models.
5post
