2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding DVD playback
      10-30-2010, 07:32 AM   #1
okram
Drives: f10
DVD playback
With professional navigation, can mp3's be played from DVD (4,7gb)?
      10-30-2010, 05:07 PM   #2
okram
Drives: f10
Super, this means something like 45 mp3 albums on one dvd. I will not need an usb at all.
      10-30-2010, 05:15 PM   #3
Touring
Touring's Avatar
Norway
178
Drives: i3,E21,M2,E23, Skoda Kodiaq
If you spend so much money on a new car, add the usb to make it complet. It works so perfect with an ipod, you will regret it later if you go for burning DVDs for your car.
      10-30-2010, 05:19 PM   #4
dpwr
36
Drives: a good one
i got 16gb usb stick plugged in, works like a charm
      10-31-2010, 11:19 AM   #5
okram
Drives: f10
for me burning a dvd is almost the same task as burning usb key.
      10-31-2010, 01:39 PM   #6
morkjt
United Kingdom
Drives: BMW F10 520d Auto Deep Sea Blu
i did get the USB option for my ipod - but when I discovered 12gb of disc space, and an easy ability to burn 4gb of mp3's on DVD, take them into the car, and copy them straight onto the hard drive....
Well, I don't ever used the iPod anymore.
      10-31-2010, 02:03 PM   #7
joy5
United Kingdom
20
Drives: xDrive30d M Sport
Why burn DVDs when you can upload with a USB stick? I found it is very slow with a CD/DVD compared to a USB upload.
2013 - x30d E70 M Sport
2010 - 520d F10 SE
      10-31-2010, 05:29 PM   #8
nosnoop
838
Drives: 5 Series
Do you unplug your USB flash drive when you turn off your car?
I found that the access light of the USB flash drive kept blinking away after the car was off! So I removed the drive. I was planning to leave it plugged in.
      10-31-2010, 05:44 PM   #9
1HOT BMR
1HOT BMR's Avatar
Drives: Car-less and shopping +'12 35d
Do you see the album covers and can you control the drive in any way - like moving from album to album and shuffling?
      11-01-2010, 10:39 AM   #10
nosnoop
838
Drives: 5 Series
Yes, you can do that. It's like any other source.
      11-01-2010, 11:21 AM   #11
dpwr
36
Drives: a good one
no I don't unplug it, always have it plugged in. did that since day one no issues....
      11-01-2010, 11:22 AM   #12
dpwr
36
Drives: a good one
yap, you can see album folders and everything under playlists...
      11-01-2010, 01:12 PM   #13
okram
Drives: f10
do you see album folders also when playing from disk or dvd?
      11-01-2010, 01:16 PM   #14
dpwr
36
Drives: a good one
not sure, I only used usb and iphone, but i'm sure disk/dvd works same
      11-02-2010, 02:59 AM   #15
okram
Drives: f10
can anyone please check?
      11-03-2010, 09:23 AM   #16
gorban
Sweden
11
Drives: F11 520xdAT, E87 120dM
The USB connection will be switched of once you lock the car. In the same way, the car will start up the USB once you unlock the car. This way the music will start to play immediately when you press the start button without any delay.
Current: 2014 F11 lci 520xd Touring, Imperial Blue
5post
