ER charge pipe leak?
11-08-2010, 09:44 AM | #1 |
Rep 634
Just wondering I checked all my connections and they were all tight. Yet I still have a boost leak. Could the er charge pipe be leaking near the throttle body.there is oil residue there and its only a flange. Was thinking about buying a coupler and trying to seal it..
05-12-2011, 12:32 PM | #3 |
Rep 3,730
Mine has been on for over a year, works perfectly fine. Just check your connection at the throttle body. The oil is blow-by, it's perfectly normal, just get an OCC to reduce it.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
JC_AD335i27.50 |
05-12-2011, 02:19 PM | #6 | |
Rep 993
05-12-2011, 02:52 PM | #7 |
Rep 854
i have the ER Charge pipe, i got it installed at at ER as well. Don't believe i have any problems.
How can you check for boost leaks? I've been wondering for the longest time
10' Solid Red GTR
08' 335i 6MT - Sold 92' NA 300ZX 5speed - Sold 06 IS350 - Sold |
05-13-2011, 06:01 PM | #10 |
Rep 183
Some people do pressure tests by using an air compressor. Or if you had a boost gauge and you're not hitting 8.8PSI (stock) then you're having a leak. If you get JB4 you can turn your fuel gauge into a boost gauge, it's awesome. For me...i'm supposed to be hitting around 14-15 PSI but i'm only getting about 10 which is telling me i'm having a leak.
05-13-2011, 06:03 PM | #11 |
Rep 183
Maybe i just didn't push in the CP enough. My pipe wiggles a little bit if i push up/down on it. I have the O-Ring installed plus I was able to install that metal clip that attaches to the throttle body.
05-13-2011, 06:04 PM | #12 |
Rep 183
05-13-2011, 06:33 PM | #13 |
69
Rep 1,943
When the CP on correctly it Should NOT wiggle, move or anything at all not even a hair! It should be tight as the stock one!! If it moves then get in there take ur time and get it right!! Is a bit tricky but be patient with it. If and it is put ur stock one back on and try that to make sure it is ur CP
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
05-13-2011, 06:36 PM | #14 | |
Rep 993
05-13-2011, 07:50 PM | #15 | ||
69
Rep 1,943
05-13-2011, 07:51 PM | #16 |
69
Rep 1,943
Check also if u have oil inside of the CP due to blow by! And clean the O-ring good! Try that!
05-13-2011, 09:00 PM | #17 | |
Rep 183
Cool. Thanks for the response. I was guessing it was that but i wasn't too sure how the fitment was supposed to be in the first place. As long as i got that clip in there I thought i'd be good to go. Don't even remember how the stock CP was fit on there because all I cared about was trying to pull that thing off. lol |
09-11-2011, 01:26 PM | #18 |
NeedsMoarBoost
42
Rep 527
Def no wiggle ? I got my cp from a guy who had a 135 and told me there is a little plat in the pipe once installed. Which is the case for me to
Can Anyone Please confirm this before I go back in there ? |
10-19-2013, 08:14 AM | #20 |
underground
64
Rep 332
Drives: alpine white 335 E92
My ER charge pipe wiggles a tiny bit. (Only when forced by hand) Boost is 18psi no leaks. Make sure you have the O-ring installed, metal clip in, & have the 1 nut tight and your good.
10-19-2013, 09:09 AM | #21 |
Rep 2,204
I've got some play on my charge pipe and all seems fine (or so I thought)
I also have a JB4 so going to test boost on petrol gauge. However how do you know that you could be under boosting? Ie how does psi relate on the fuel gauge?, where on the fuel gauge is say 10 psi ? Cheers
Engine Mods: VF HEX Stage 2, ER Charge Pipes, VRSF Catless Downpipes, BMS Intakes and PCW Exhaust Mod
Running Gear Mods: HRE Flow Form F01, Yellow Stuff pads. Cosmetic: Performance Grill, Lip Spoiler, Splitters, Side Skirt Extensions, Diffuser and BMS Tips |
10-19-2013, 09:22 AM | #22 |
underground
64
Rep 332
1/4 tank= 5psi 1/2 tank = 10psi 3/4 tank =15psi full tank=20psi do a log and you can tell if you have a leak. (Target boost vs actual boost)
