2010 2011 BMW 5 Series Forum F10 will E60 M5 wheels fit F10 535i?? |
11-22-2010, 02:10 PM | #1 |
Rep 103
E60 M5 wheels
front is 19X8.5 +12 rear is 19X9.5 +28 will it fit F10? I found this pic.. Last edited by FusionBlitzz; 11-26-2010 at 01:46 AM.. |
11-22-2010, 03:10 PM | #2 |
Rep 4,721
Based on the calc., assuming non-staggered setup.
For front, the M5 wheels will have +21mm clearance on the strut and the wheel will extend out +21mm For rear, the M5 wheels will have +10mm clearance on the strut and the wheel will extend out +16 mm. Technically, it should fit. But I don't like the wheel to be extended by that much and thereby putting more stress on the wheel hub and there is a chance it could rub the fender. Just my opinion. You should still do an ACTUAL test fit to make sure it clears. Last edited by bobblehead; 11-22-2010 at 03:16 PM.. |
11-22-2010, 04:23 PM | #3 |
Rep 1,087
Drives: F10, F13, current->F80, F15 X5
It maybe a lil too aggressive on the front!
Im on 21 by 9 +32 and its flush flush and 21 by 10.5 +40 and its right on the fender so going with calculations your rear should be fine, but the front is too aggressive |
11-22-2010, 07:09 PM | #4 |
Rep 103
what offset will be perfect for 19inch wheels.
8.5 front and 9.5 rear? or maybe 9 in the front 10 in the rear? 19X8.5 + 20 19X9.5+ 20? or 19X9 +30 19X10 +30 |
11-22-2010, 07:12 PM | #5 |
Rep 1,087
19 by 9 +30 front
19 by 10 +34 or 35 should be good! |
11-26-2010, 08:08 PM | #9 |
Rep 103
Front alloy wheels: 20x8.5" ET33
Wheel part number: BMW 36116792598 Rear alloy wheels: 20x9" ET44 Wheel part number: BMW 36116792599 I went to local BMW Dealer Check out the 20 " 356 style wheels on 535I Rwd..the front almost flush .like 5mm gap look down from the fender.rear is about 15mm gap.front the edge the panel...so i guss those e60 M5 wheels wont fit on F10 535I rwd |
11-27-2010, 11:27 AM | #10 |
1566
Rep 29,202
