e90 sport wheel alignment
12-08-2010, 03:39 PM | #1 |
Rep 102
Hey guys,
I have a e90 (330i) with sport package and still have the OEM 18" rims. My rear tires are gone, and needs replacement, and though I still have a bit of life left in my fronts, I have decided to ditch all my RFT and get the Michelin Pilot Sport PS2. However, immediately after getting the tires I plan to also get them aligned. My question is, what is the proper alignment spec for my car? Since there is a difference between the sport and non-sport, it just seems that it would be likely that the shop would get it wrong if they don't pay attention, so I want to make sure that it's done properly by having some numbers that I can cross reference. While we are at it, any thoughts on my choice of tires? I have read through quite a bit of posts, and the PS2 seems to be a popular choice. And are there any difference between the Pilot Sport and the Pilot Sport PS2? Thanks! |
12-09-2010, 01:46 AM | #2 |
Rep 31
Always a good idea to get a proper alignment after spending some glue on a good set of tires.
You can have get a non-aggressive alignment that will allow the tires to last longer, or you can get a more aggressive alignment that will make the car handle better, but could reduce tire life by 50%. I trust only one guy in SoCal. Darin at West End Alignment in Gardena. He took care of my P-cars, and there are no gorillas in his shop as he does all the work himself. BTW, you cannot go wrong with either Michelin, but I would go for the PS2. Newer design. Good luck.
2009 335iC SG|CR|GP|6M Sport|Premium|Cold|Nav|Logic7|HD|Eibach Pro|35%|MFD Scoops|K&N|non-RFT
12-09-2010, 09:02 AM | #3 | |
Rep 1,256
Getting an alignement after purchasing new tires is the smartest investment you can make in these matters. Personally, I would not get the alignment done anywhere but at BMW. The alignment on BMWs is done correctly using some expensive machinery and their methodology deals with weight and counterweight added to different parts of your vehicle. There is NO SHOP that I have heard of that will do this alignment properly. This is the only thing we spare no expense on when doing it and just get it done at the dealer. Hope this helps! |
12-09-2010, 05:41 PM | #4 | |
Rep 102
12-10-2010, 09:44 AM | #5 |
Rep 463
Don't get the PS2s... look at my other thread... Continental ExtremeContact DW is better in every way, according to TireRack testing...
Just figured all this out today so I thought I'd share and save you $240 per set! (I'm on a bit of a rant against the PS2s coz I have been stupid to buy them for years for want of a proper alternative.) |
12-10-2010, 10:11 AM | #6 |
Rep 494
An alignment at BMW is expensive. My local dealer had a coupon for $200 so who knows how much the regular price is.
If you are an aggressive canyon driver I would say put some negative camber in the front so you don't burn the outside of your tires. I would guess -.5 - -1. depending on how much canyons you do, if you do a lot of them put more. Toe should always be 0. |
