Wheel ideas
12-10-2010, 01:37 AM | #2 |
475
Rep 13,583
Drives: JB E92 335i
I would recommend that you check out the Forgestar F14 Flow Form wheel if you're looking for a light weight 18" wheel. Flow Form Casting is a production procedure that turns the wheel (or rim section) over a special mandrel and three hydraulic rollers using tremendous pressure. The pressure and turning then force the rim area to form against the mandrel, creating the shape and width of the rim. During Flow Forming, the rim actually "flows" down to create the full rim width. During Flow Forming, pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel.
Forgestar wheels are also much lighter than cast wheels. The 18x8.5 F14 wheel weighs an amazingly light 17.6 lbs, where a cast wheel of this same size would weigh anywhere from 23-27 lbs. This saving of roughly 6-10 pounds per wheel makes a BIG difference in regards to handling and drivability. Reducing unsprung weight (weight that is not supported by the car's suspension, i.e wheels, tires, brake rotors, and brake calipers) is one of the easiest ways to improve your car's handling, braking, and acceleration. As a general estimate 1 pound of unsprung weight is equal to 10 pounds of static weight. (weight that is supported by the vehicle's suspension). By using this ratio if you were to replace your stock wheels that weighed 25 lbs with Forgestar wheels you would be saving 320 lbs. in static weight! I'll go ahead and shoot you over a PM with more details. In the meantime, here are a few pictures for you to check out. Forgestar F14 in Matte Black on a 2011 BMW E92 335i Front: 18x8.5 Rear: 18x10 [IMG]http://www.**********s.com/images/Products/Forgestar%20Wheels/Gallery/pic05.jpg[/IMG] [IMG]http://www.**********s.com/images/Products/Forgestar%20Wheels/Gallery/pic09.jpg[/IMG] [IMG]http://www.**********s.com/images/Products/Forgestar%20Wheels/Gallery/pic07.jpg[/IMG] |
12-10-2010, 03:15 PM | #3 |
BimmerPost Supporting Vendor
2042
Rep 25,989
Feel free to take a look at our VMR V701, V710, or VB3 wheel.
All are offered in 8.5/9.5" setups in HS, GM, or MB. -Charles@VMRWheels V701 V710 VB3
VMR|Wheels | 714.442.7916 |
12-10-2010, 03:21 PM | #4 |
Rep 3,879
I would got for some 19" BBS CH, they only weight ~20lbs and are very strong and a timeless look. Let me know if you need help on a setup, ive got some end of the year sales on BBS
12-12-2010, 08:57 AM | #5 |
Rep 15
