Anyone know how to remove plastic Seat trim??
01-13-2011, 02:08 PM | #1 |
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
This right here. i went realoem.com and they have a diagram but still i have no clue how to get it off....felt around underneath with my fingers and i feel some clips i tried to unhinge, which it did, but it was still on pretty tight..
this plastic is squeaking like mad...need to put some padding in there. |
01-18-2011, 01:36 PM | #3 |
Rep 2,928
yes, please someone chime in. thanks
01-23-2011, 11:15 AM | #6 |
Rep 17
Here's e46 diy. see if you can get some points on generally removing a seat and modify as you see.
http://forum.e46fanatics.com/showthread.php?t=657042 |
03-04-2011, 11:39 PM | #7 |
Rep 21
Did someone figure this out? I saw the post for the e46, and it helped a bit. There are clips, but it seem like there is something else holding the cover on near the switch assembly.
03-05-2011, 12:42 AM | #8 |
Rep 2,928
please someone chime in.i would love to know how to take this off....save me a trip to dealer....i do feel clips underneath but when i try to press them in and pry, it wont budge...dont want to crack and rip the plastic off.....for sure it can probably be taken off if u remove the entire seat but thats a hassle too...gotta be an easier way....i mean, how do those people who replace the plastic with the CF trim do it?
03-05-2011, 02:05 PM | #9 |
Rep 8
Just take the seat out first, and then you'll see where to pry to get it off.
If it works the same as the non-electric sports seats you'll have to: 1. Remove the negative battery lead 2. Wait for a few minutes (we don't want any fault-codes) 3. Remove torx screws from front and back of seatrails 4. Push seat backwards in order to see to seatbottom 5. Remove wiring from junction-box 6. Lift seat out You probably have to remove the seat adjustment modules first and then the whole sidecover. Get an L-shaped "pick" to pry the "nails" up on the backside of the sidecover. It should't be much of a hassle, maybe half an hour of work. |
02-17-2013, 10:38 AM | #10 |
Rep 13
This linked thread has the pdf that is most helpful for this procedure. I am just updating this thread because this one is the most frequently returned via google searches and doesn't have the most relevant info:
http://www.e90post.com/forums/showthread.php?t=794807
328xi A22/Sparkling Graphite Metallic w/Schwarz Leatherette - All stock.
