indicator issues
01-26-2011, 11:02 PM | #1 |
Rep 65
indicator issues
Hi All
Well my front right indicators seems to playing up and im not sure what the problem is. The warning light comes up and disappears every now and then. At first I thought it was the light bulb so I've changed it and it still happens. Sometimes the indicator works normally and sometimes it doesnt. I have made sure that everything is tight and not loose. I have no idea why its doing this but thought I'll see if anyone else had similar issues first before taking it to the mechanic. Thanks |
01-26-2011, 11:03 PM | #2 |
Lord Captain Commander
110
Rep 3,093
My first thought would be the bulb, but if you've changed that then I have no idea.
Sounds like a BMW style electronic glitch
E82 135i M-sport: SGM/6MT/Black |
01-26-2011, 11:13 PM | #3 | |
On the hunt for PSI
41
Rep 778
2016 Alfa Romeo Guilia Quadrifoglio - Metallic White |
01-27-2011, 03:40 AM | #8 |
86
Rep 1,993
A fuse is either good or bad, they don't suffer from being 'on their way out'.
Vishnu PROcede V5 | VK Motorworks FMIC | AR Design OCC | Forge DV's | Bilstein PSS9 | M3 Lower Control Arms & Caster Rods | Quaife LSD | HiTech Exhaust | BMW Performance Illuminated Door Sills | BMW Performance Gear Selector & Boot | BMW Performance E-Brake Cover
01-27-2011, 04:08 AM | #9 |
23
Rep 451
01-27-2011, 06:07 AM | #12 | |
spectator
81
Rep 507
Well even if it's not on its way out, it should be on its way out of the fusebox. |
01-27-2011, 07:21 AM | #13 | |
110
Rep 3,093
Hit a bump and they'll separate again.
01-27-2011, 06:20 PM | #14 |
Rep 65
well i gave it a "technical tap" and it got it going for a few seconds and then back to nothing. Decided to give it a few more "technical taps" but didnt seem to work the second time around
I'll take a look at the fuse tonight Thanks for the input guys/girls |
09-20-2011, 08:52 PM | #15 |
Rep 65
Well my problem is back and is annoying as hell. I've checked everything and just cant find the problem.
I've taken it to the mechanic but when I got there, the blinker decided to work so they couldnt test it or see an issue with it. I've tried this a couple of times now but every time i decide to take it to the mechanic it decides to work again. It seems like the blinker knows everytime im planning to go to the mechanic and toys with me! Any ideas anyone? |
09-20-2011, 08:55 PM | #16 | |
43
Rep 1,719
09-21-2011, 12:52 AM | #17 | |
Rep 104
Drives: 335i (sold) 997.2 Carrera S
The answer is generally to replace the bulb and/or clean the bulb contacts and make sure that the receptacle contacts are not corroded / bent / worn. Hope that helps get you further. |
09-21-2011, 07:15 PM | #19 |
Rep 65
I've tried replacing the bulbs and checked the contacts on the actual plug thing you pull out. Everything seems okay on the end you pull out. It must be the other end which I havent been able to check yet. Its just so hard to see anything.
I think it might be the from the the plug thing to the actual head light that is stuffed. Sorry about my non technical terms. I'm pretty crap when it comes to that stuff |
