Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > General 6-Series Coupe, Convertible, and Gran Coupe Forum
      02-07-2011, 10:15 AM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Post Autocar 650i Convertible Review - Better All Around Than Predecessor
BIMMERPOST NEWS
Autocar Reviews New 650i Convertible
COMMENTS
Autocar UK provides its first drive review of the all new 650i convertible, calling it a positive step forward and a more complete car than its predecessor - in all areas. Here is what they had to say.
What’s it like?
Gone is the bullish and bloated look of the old model, replaced by a much more elegant and cohesive lineage. Not surprisingly, given it is based on the same underpinnings as the latest generation 5-series, the new 6-series cabriolet has grown in length and width, putting on 74mm and 39mm respectively, although height is down by a scant 8mm – all of which serves to give it a longer and more lithe profile together with a more confident and athletic stance.
As with the exterior, the interior has also been thoroughly reworked, with a unique dashboard and centre console – the latter now angled slightly towards the driver for a more cosseting feel than that of the old 6-series cabriolet. The perception of quality has also received a welcome lift thanks to the inclusion of higher grade materials and added attention to detail.
The increased dimensions provide front seat occupants with plenty of accommodation, although entry is impeded somewhat by the heavily raked nature of the windscreen despite the generous length of the doors, which like the bonnet are fashioned from aluminium in a bid to trim weight. The individual rear seats, like those up front, are generous in size but, for a car measuring almost five metres in length, lack for any real legroom and are not at all easy to climb into with the roof up.
As with the first-generation 6-series cabriolet launched in 2004, this new one uses a fabric hood that can be operated at speeds up to 40km/h. The vertical rear window, which can be automatically lowered into the rear bulk head via a switch on the driver’s door, is brought over from the old model.
Although it weighs a good deal more than the in-line six-cylinder the V8 delivers truly heady levels of performance along with extraordinary levels of refinement.
Despite lacking the automatic stop/start system that will be standard on the 640i cabriolet here in the UK, BMW claims the new 650i cabriolet’s engine records a slight two per cent reduction in fuel consumption over the naturally aspirated 5.0-litre V8 it replaces in the 650i cabriolet at a combined 26.4mpg.
On light to moderate throttle loads even with the roof down there is an almost complete lack of mechanical intrusion into the cabin, making the new BMW a serene boulevard cruiser. Bury your foot, though, and there’s an alluring burble back through the exhaust.
Out on the open road, the new 6-series cabriolet feels terrifically solid with very little scuttle shake even over nasty ruts, and, crucially, is a good deal more entertaining than its predecessor. It changes direction with added eagerness and, despite its vast array of electronic driving aids, can be relied upon to adjust its line mid-corner.
BMW says overall stiffness has been improved by a remarkable 50 per cent, both for dynamic and ride characteristics, along with a more direct action for the front steering and, in a first for the up-market open top ranks, the addition of the BMW’s Integral Active Steering.
As far as driving characteristics are concerned, it is really a matter of what chassis setting you choose. As with high end versions of the new 5-series and the larger 7-series, BMW’s Dynamic Drive system allows you to select between three different modes: comfort, normal and sport. A further setting, sport plus, also delays the intervention of the stability and traction control systems to give you a further dimension.
Normal is the mode of choice for everyday running, providing an excellent blend between ride quality, body control and overall response. It better suits the new car’s athletic character than comfort mode, which unnecessarily softens up the suspension, introduces added body roll and takes the sharpness out of the steering.
For more spirited driving, sport mode is definitely the way to go. At first it feels overly aggressive owing mainly to the increased turn in qualities provided by the rear wheel steering. But find an empty back road and you quickly come to appreciate the added directness, which provides this nearly two tonne open top with the sort of agility usually associated with a much lighter and more focused performance car.
Should I buy one?
The new 6-series cabriolet is clearly a more complete car than the one it replaces. From the added elegance inherent in its styling, through the improved quality of its interior, increased performance potential, reduced consumption and more entertaining on-road qualities, it’s a positive step forward and a much more worthy rival to the likes of the Jaguar XK cabriolet and Mercedes-Benz E-class coupe.
It certainly bodes well for the upcoming 6-series coupe, which by way of an even more rigid bodyshell promises to be an even more exciting proposition.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
      02-07-2011, 11:52 AM   #2
Augu$tu$
Drives: BMW 1M
This sounds like somebody from BMW wrote this. Autocar reviews are terrible.
      02-07-2011, 01:21 PM   #3
BMWPower06
A^M=G is nothing w/o the Power of ///M
BMWPower06's Avatar
Drives: ///M5 & ///M3
someone from BMW would know that the previous 650 had a 4.8L V8 not a 5.0L
Indianapolis Red BMW ///M5
      02-07-2011, 01:23 PM   #4
Frosty
Frosty's Avatar
773
Drives: M240i - 2021 - 6MT -
+1
M240i Coupe (6MT) (2021: 6/2021 build )
Accord Coupe (6MT) (2017)
335i Coupe (6MT) (2007: 9/06 build SOLD 8/2016)
Prelude (5MT) (1995)
      02-07-2011, 08:56 PM   #5
MDivPower
MDivPower's Avatar
Egypt
Drives: mk4 Jetta
6post.com
