Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > 18" 313 wheels off the 335is with a square setup?
      02-07-2011, 10:42 PM   #1
jerflash
jerflash's Avatar
Drives: 2007 E92 328xi/2002 ws6
i just found out that they make these and i love them.
what do you guys think of this for my 328xi. these OEM wheels can be had from tisher for under 1500 shipped and they are made by bbs and should stand up to NYC roads alot better then the 19" 313s. Plus they look dead sexy. Rotating every season when i put my winters on is not bad either
i was thinking about buying 4 18x8(et34) or 18x8.5(et37) and running 225/40/18s, 235/40/18s, or 245/40/18s all around.
what do you guys think...good idea for an xi or should i just do the staggered setup?
thanks
joe
Daily Driver: 2014 428i MSPORT MINERAL GRAY W/ CORAL INTERIOR PICKED UP ON 9/28!!
Racecar: 2002 Trans Am WS6, Red w/Ebony Leather...Loud and Fast.
      02-08-2011, 09:56 PM   #2
cb4
cb4's Avatar
Drives: 2008 335xi
I bought this setup from Tischer last summer. I went with 8.5et37. Primarily to give me some flexibility in going to a wider tire. Right now I have 245/40s mounted on these.
Tischer was great and the wheels are excellent!
      02-08-2011, 10:33 PM   #3
335iPSI
PSI
Drives: 2011 AW 335D
Anyone have pics of this?
2011 335d, M-sport, Alpine White, Nav
      02-08-2011, 11:07 PM   #4
jdot
Drives: 07 328i E90
I have the MiRo 942 which is a 313 rep. I'm running on a staggered setup on 18's with ZSP. I have a 328i not xi.
07 E90 328i | MB | ZSP | ZCW | ZPP | De-badged | Black Matte Grill | BMW Performance Exhaust | 18" Miro 942 | Interior LED kit | Akebono Brake Pads | BMS PBX |
      02-08-2011, 11:49 PM   #5
jerflash
jerflash's Avatar
hey cb4 do you have pics of this setup on your car? Do they rub anywhere in the front? 245s all around would be awesome on some 8.5s
      02-09-2011, 12:09 AM   #6
jerflash
jerflash's Avatar
a set of staggered miros from **********s are 1000 shipped. the oem 313 from tisher is only 400 bucks more shipped. to me 100 bucks more a rim is well worth it. stronger, stock bmw cap fits and made by bbs...besides they would also be covered under bmws wheel protection if you have it on your car
      02-09-2011, 07:04 PM   #7
cb4
cb4's Avatar
Drives: 2008 335xi
No rubbing at all. I'll post Picts later.
      02-09-2011, 07:31 PM   #8
jerflash
jerflash's Avatar
cool thanks bro.
      02-09-2011, 09:15 PM   #9
cb4
cb4's Avatar
Drives: 2008 335xi
iPhone quality but should give you an idea.
      02-09-2011, 10:07 PM   #10
jerflash
jerflash's Avatar
looks awesome and there is a good amount of sidewall to keep the rims safe.
i see you have the extreme DW...would you recommend them? i was thinking of them or the hankook v12s, firestone wide ovals, PS2s, or Bridgestone RE760 Sport
im leaning to DW
      02-09-2011, 10:18 PM   #11
cb4
cb4's Avatar
Drives: 2008 335xi
im leaning to DW
Go DW! Amazing wet traction and dry grip. I'd buy them again.
The sidewalks are a little taller then the stock 225/40. It does give a little more pothole protection.
      02-09-2011, 10:22 PM   #12
cb4
cb4's Avatar
Drives: 2008 335xi
I also wanted to mention that this setup provides neutral steering. I run 36 psi on all corners. I haven't tried a staggered setup so can't compare, but I do love the square setup.
