BMS Powerbox for 325i, any feedback?
02-13-2011, 05:28 AM | #1 |
Rep 421
Hi guys, I am thinking of purchasing a BMS Powerbox from the US. These are supposed to fit all N52 2.5L engines.
Does anyone have one installed? If yes, have you noticed any real gains in HP or throttle responsiveness? |
02-13-2011, 05:32 AM | #2 |
Rep 5,530
All the BMS PBX does is amplify the voltage from the fly by wire throttle and modify the paramaters of air/fuel so the engine runs rich.
If you're interested in a real tune, we're trying to organise a group buy at the moment, should give you ~7kw or so for a very modest ~$500 but it'll improve responsiveness http://www.1addicts.com/forums/showt...=483444&page=4 |
02-13-2011, 06:31 AM | #4 |
Rep 421
Thanks bmroxm5, but I'm not really interested in that type of tuning.
BMS powebox has been tried and tested - I am primarily interested in killing off the lag in responsiveness. Happy with current power from my 325i and not planning in doing anything more radical than maybe fitting a Remus exhaust (long term project). This is my mini project for the next couple of years. After that I will be looking at upgrading up to 535i. |
02-13-2011, 07:17 AM | #5 | |
Lord Captain Commander
110
Rep 3,093
Hp gains are probably negligible
E82 135i M-sport: SGM/6MT/Black |
02-13-2011, 02:54 PM | #6 |
Rep 2,643
Doesn't the 125i use a 3.0 Litre engine similar to what is used in the US spec 328i?
Anyway I am certain that it is a different engine from the 2.5 litre engine fitted to Australian delivered 325i E90 and E92. Normally I'd have doubts about using a plug-in upgrade designed for a different engine with lower octane US fuels. |
02-13-2011, 04:12 PM | #7 | |||
Rep 5,530
How which one works?
BMS PBX - fools your engine into thinking that it needs more fuel so the engine runs 'rich'. In addition, because our cars use a fly by wire throttle, the PBX will amplify this voltage. Which means when your accelerator is halfway down, the voltage is double (when set to 100% gain) meaning the car will accelerate as if it were at wide open throttle. The disadvantage of this is that between halfway and all the way down to the floor, there is no difference in acceleration. It basically compresses the range of your accelerator pedal into half the travel, meaning each little press results in more acceleration. The disadvantage to your car running rich is that over time, the engine will autocorrect itself and you won't have any HP gains. Many people will have this feeling that their 'pbx stops working' after 6months or so. The 'tune' is a real tune that will modify air/fuel ratios as well as timing on our engines so as to extract more power. Quote:
I assume you're adding a Remus exhaust for more power? For the money the gains have a worse $/kw ratio than a tune and if you want noise there are other options out there. What's the goal here? Quote:
02-13-2011, 05:11 PM | #8 |
Rep 231
Map 7 for me. More pull than stock for sure. Map 3 messes up with the transmission gear changes for some reason it's just not as smooth and it's shifting all over the shop in day to day driving.
AC Style Strut Brace/ Koni FSD/ Eibach Pro/ BMW Performance Brake/ BMS PBX/ K&N Cone filter/ Retro-fit paddle shift/ Black shadowline/ Matt Blk Grill/ MTEC Angel eyes
02-13-2011, 06:59 PM | #10 |
Rep 137
@bmroxm5
About the real tune, how hard is the installation ? If its really easy, count me in for the group buy I got 325i E93 2007 , I dunno about the engine |
02-13-2011, 07:46 PM | #11 | |
Rep 2,643
1) Roughly how much power / torque gain can we expect when using a standard exhaust? 2) Will the tune allow the car to run on E10 fuel? |
02-13-2011, 08:28 PM | #12 | ||
110
Rep 3,093
Problem is, if your dealer decides to give you a software update then you'll have to get the flash again. Quote:
You definitely cannot run on E10 fuel, I believe it specifies 98RON. I don't think you should be running E10 in your stock car anyway. 323i's should be fine, since the tuning is available in Canada for the 323i
02-13-2011, 10:33 PM | #13 |
Rep 5,530
Canadian 323 is different to our 323 though.. in fact I think their 323 is the same as our 325i... will double check on its suitability for Aus spec 323s. Would be a great result if the Aus spec 323s could be flashed to same power as 325s, because afterall they are both running N52B25 engines but the 323 has a lower state of tune.
Just like the 125i has the same N52B30 engine as the 130i/330i/530i with a lower state of tune. @ MrBBQowner - install will be quite easy. We'll arrange a meet in Sydney and get everyone 'flashed'. @ Spikey - I guess i'm acting as the unofficial liason for the E9Xs on this and the actual group buy on 1addicts. You're in Brissy correct? Am sure we can work something out. @ John - I'm hoping for 7kw atw gain from just the tune. Bolt on mods will yield more gains, especially with a freer flowing exhaust. Speaking of exhaust I was talking to a guy who managed to massage 33 rwkw out of an E46 330ci by adding hi flow cat convertors, 2 x 2.25inch piping the whole way back and retaining the OEM muffler in conjunction with K&N drop ins and a tune. He believes the headers are quite efficient from factory anyway so didn't change those. Unfortunately price he quoted me for all this was $5k+ so I will see if I can get this 'off the shelf tune' (as opposed to his custom one) and combine it with a freer flowing exhaust in the near future to see some decent (~20rwkw) gains. |
02-13-2011, 11:41 PM | #15 |
Rep 2,643
I just asked about the E10 because I am not sure if 98 is always available if I travel to very remote country locations. Maybe I could use an octane booster if that ever becomes an issue for me.
7kW seems like an acceptable increase for a software only upgrade. The headers in my E90 325i include the cats. They are the primary and only cats in the stock exhaust system. Apart from the headers, the only other restriction in the E90 exhaust is the resonator and the muffler. |
02-14-2011, 12:25 AM | #16 | |
Rep 960
02-14-2011, 01:08 AM | #17 | |
Rep 5,530
great! I'll put you on the list and we'll see what we can do.
I'm yet to have my car up on a hoist and have a good peek around but I'll take your word for it there are no secondary cats? In that case to get decent gains we'd have to go catless headers followed by hi-flow cats. I'll double check the applicability to the 323i and keep you posted. |
02-14-2011, 01:31 AM | #18 |
Rep 137
02-14-2011, 06:09 AM | #19 |
Rep 5,530
OBX Headers with O2 sims are available pretty cheaply, less than $500US.. add $100 for postage and $300 for install and I reckon you're looking at under a grand for 10-15kw at the wheels.
The only problem is you will now be catless, therefore driving illegally, so I'd recommend adding a highflow cat at a cost of $200. For the environment and for peace of mind just in case you were to ever be found out running catless. Maybe this can be the next group buy lol. MrBBQwer whats your ultimate goal performance wise? and budget wise? Personally I'm happy with a tune for a few more ponies for $500.. maybe a freer flowing exhaust system for a grand, but after that I'd much rather save for a 335i. As an E93, you'll also unfortunately always have that ~200kg weight penalty over the coupes. |
02-14-2011, 02:20 PM | #20 | |
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
It is fantastic when set to map 3. Engine responsiveness is really boosted somewhat and the car feels like it should have come out of the factory like that. The PBX Powerbox is great value for money, especially with parity $. Remember, there isn't very much that one can do to improve a BMW NA I6 engine, so PBX has taken it to the best they can. Easy to set to Map 0, being stock or set it to any of the other maps within seconds. It is not recognised by BMW's computers during service. You can remove it if you want once you have finished with the car and sell it. Win win situation. I love it. Andrew at Southern BM in Moorabbin, Melbourne installed mine. Go for it Cheers
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
02-15-2011, 04:54 AM | #21 |
Rep 421
David325 thanks for your response. I am glad to hear that it has improved the feel of the car. Can't wait to get my hands on one.
Yours was installed at SouthernBM. Did it cost around $700? I am looking at buying direct from US for approximately $300 and either installing it myself or getting a good auto eletrician to do it for me. Has anyone installed the BMS Powerbox themselves? |
02-15-2011, 06:03 AM | #22 |
Rep 5,530
I'll answer on behalf of David here if he doesn't mind lol, he got his from Mike @ N54tuning and installed at SouthernBM.
It really is a great mod, especially for the auto vehicles. For those just starting to look into it, don't confuse it with a 'tune' though which actually alters valve timing. PBX is great to eliminate throttle lag, but a tune is discussion for a different thread. |
