DIY - Hidden NonOEM Garage Door Opener Install
03-01-2007, 01:48 PM | #1 |
Rep 20
I couldn't justify the price of the rearview mirror with UGDO, so I hardwired a universal door opener I got for $30.
I installed the push button switch in the ashtray, in case I ever want to put it back to stock, the ashtray is a cheap item to replace. It got kind of late so, I forgot to take pictures. Here is the basic idea of what I did and the pictures that I did take. 1. Solder wires to the garage door opener switch and power terminals. I used terminal block connectors, so I can easily disconnect everything. This part will vary depending on your garage door opener. You could leave the battery in the door opener and not hardwire the power. 2. Remove the centre console. Instructions can be found here. http://e90post.com/forums/showthread.php?t=7049 3. Remove the panel under the glove box by taking out the two torx screws. 4. Run the wires for the power/ground and the switch from the centre console to the passenger side foot well. Connect the wire block connectors to the wires. 5. Splice the power and ground wire to the ashtray power plug. The connector has three wires and can be disconnected so the centre console trim and ashtray can be removed. I spliced it to the connector side that is left behind. Use a DVM to determine power and ground. Sorry, I forgot to take pics. 6. Stash the garage door opener on the passenger side of the car behind the panel under the glove box. I didn't need anything to hold it on place. It slid in tightly and will not move. (Note. You will obviously not get the same range with the door opener placed under the dash. I did notice reduced range, but I still have sufficient range to open the door before I drive up to the garage. You should test placement of you door opener before picking a permanent spot.) 7. Remove the ashray and drill a hole for the switch. I needed to drill a 9/16" hole. Using a glue gun, glue the switch in to place. 8. Connect the power and switch wiring to the garage door opener. Connect the wiring to the ashtray switch. Turn on the car and test the opener. 9. Tie up the wires with some tie straps. Re-install the panel and console and you are done! |
03-01-2007, 01:56 PM | #2 |
Rep 1,018
Drives: 2014 BMW M5
thanks for the nice write up, and a very good idea! think i'm gonna attempt that!
03-01-2007, 10:24 PM | #4 |
Rep 990
damn good mod! I think I just found my next project.
BMW : Sine qua non
Mods: Blacklines | Rear Seat Power Outlets | Rear Fog Lights | Ashtray Garage Door Opener |
03-02-2007, 03:57 PM | #5 |
Rep 3,618
Thats pretty sneaky, very good write-up! I remember reading that thieves now might break into a car to take the door opener (which is commonly clipped to the visor), along with insurance/registration papers commonly found in the glovebox, then go to the person's home and see if there is a door leading into the house from the garage.
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone 2010 Mercedes-Benz C350 4Matic - Gone 2006 BMW 330xi - Gone 2001 Infiniti QX4 - Gone |
03-02-2007, 10:26 PM | #7 |
58
Rep 1,906
Drives: black 335i e90 PRE-LCI
cool, that's pretty nice....i miss the universal garage door opener that i had in my 325i
03-03-2007, 03:06 AM | #8 | |
Rep 20
Thanks for the compliments. I use it everyday and it works great.
My three button remote was stolen before I could figure out what the other two buttons were for. I am sure you could fit three switches in the ashtray. Quote:
This mod should work for any remote that has a button you can press. You just need to open it up and solder some wires to the button. What is a Procede remote? |
03-03-2007, 03:16 AM | #9 |
Rep 2,221
haha nice write up
03-06-2007, 01:23 PM | #10 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
I did something like that on my M3.
http://hometown.aol.com/hyperm3/Dooropener.html If anyone wants another way of doing it.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
03-07-2007, 12:55 AM | #13 |
Rep 990
I don't have the sunshade, only the heated seats. Hence, no row of buttons. But yeah, if you've got the buttons, that would likely work very well if you can tap into them easily.
BMW : Sine qua non
03-07-2007, 01:13 AM | #14 |
Rep 20
I like the idea of wiring the door opener to an unused button. I was looking for a button, but couldn't find one. Anyone know the part number for the button set in Xdrive's post? Been searching realoem, but no luck.
03-07-2007, 05:31 AM | #15 |
Torque junky
115
Rep 1,688
Drives: Remapped e90 330d
Hard wiring the remote behind one of those blank buttons (next to the rear blind button) is very appealing. I wonder if you can order a push-button version to slip in there somehow? One with a little garage door logo on it would be the dog's b*llocks
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
03-13-2007, 01:08 AM | #16 |
Rep 990
Modified Installation
Was so inspired by the OP's work that I decided to do this myself!
- For my version, I made a couple of changes (pics included) 1. I used snap connectors between the run wire/ashtray, and b/w the run wire/garage door opener, so both the ashtray and garage door opener are completely removable. 2. I located the garage door opener in the center console, under the rubber tray in the armrest storage compartment. This gives me easy access to the battery on the opener, so I did not need to hardwire into the car's power supply. Secondly, I can also still activate the opener if the switch in the ashtray were ever to fail. 3. I also very much like knowing that I can return the car completely stock for the price of the ashtray insert. The Pics: (sorry, didn't take any during construction) 1. The completed ashtray 2. View of the Run Wire on the Ashtray End with ashtray disconnected. 3. View of ashtray wiring 4. Remote is under the tray 5. Rubber Tray and Garage Door Opener Battery Cover removed, showing battery
BMW : Sine qua non
03-15-2007, 11:50 AM | #17 |
Torque junky
115
Rep 1,688
Good job! Has the range been affected by your 'hiding' the remote away in the centre console?
03-15-2007, 09:16 PM | #18 |
Rep 990
If anything, it's been improved, as there's less metal directly in the way of the transmitter. I can actually open the door from the street now, whereas before I had to be in the driveway and wait for the door to open.
BMW : Sine qua non
03-17-2007, 07:34 PM | #21 |
Rep 862
03-17-2007, 09:30 PM | #22 | |
Rep 990
... however, I spent about about $50 on this mod ($40 of which was buying a new garage door opener). How much did you spend on the Premium Pkg? (tongue firmly in cheek)
BMW : Sine qua non
