New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > E89 Z4 Classifieds > Commercial Z4 Classifieds
      03-01-2011, 01:24 AM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
>>> HP Autowerks <<< aFe Stage 2 N54 Intake
Producing 14 max horsepower and 27 lbs. x ft. torque, this radically different Stage 2 sealed cold air intake system is engineered to let maximum air in while keeping engine heat out.this intake system smoothly directs increased air flow for improved volumetric efficiency and maximum performance. So effective is the design that Intake Air Temperature (IAT) at normal running speeds with this aFe intake system is 11 degrees lower than the factory intake. Easily accessible with a satin black powdercoated aluminum cover, an washable/reusable conical air filter is enclosed in a molded plastic housing and mounted on a oval intake tube that smoothly supplies maximum air to the twin turbos. The full effect of this system cannot be felt or tested on stationary dyno and can only be fully appreciated on the wide open highway.
We've decided to sweeten the pot even more!
If you place your order with us, we will not only provide you with the discount on the aFe stg 2 intake with FREE SHIPPING, but we will also offer you one of the following:
2 FREE Bottles of Motul 600 Brake Fluid
10% off of Macht Schnell DP
20% off of Macht Schnell Air Scoops
20% off of HP Autowerks Adjustable Endlinks
>>>>>>>>> Order Here: http://www.hpashop.com/product.sc?pr...categoryId=110
with FREE SHIPPING! Spoke with aFe and they are not in stock with NO eta of when they will ship.
      03-03-2011, 11:17 AM   #2
HP Autosport
Drives: F80 M3
      05-05-2011, 06:34 PM   #3
HP Autosport
Drives: F80 M3
In stock now!
      06-12-2011, 11:17 AM   #4
evilstib
Bimmer Newbie
22
Drives: CSM N54 Prem/Comf/Sound
Anyone Dyno one of these yet? If so, plz post!
      12-16-2012, 10:10 PM   #5
kneedeep
Drives: m coupe
did anyone ever install one of these?
      12-16-2012, 11:43 PM   #6
HP Autosport
Drives: F80 M3
This by far has been the most popular intake for the 1M guys!
      12-21-2012, 02:34 PM   #7
kneedeep
Drives: m coupe
Is this a simple drop-in for the Z4? Does it add any sound on the intake side?
      12-24-2012, 08:52 PM   #8
HP Autosport
Drives: F80 M3
Should be a direct fit on the N54 engine. You will get a slight increase in intake sound, but nothing too drastic since it is a sealed intake.
zpost
