BBK Options?
03-05-2011, 06:32 PM | #1 |
Rep 689
BBK Options?
What do we have for options for BBK's, id like to get a set of brembos/ Stoptech but cant seem to find anything for XI specific. and brakes are not something i want to put to chance and hope they fit. Post links of what you find
KING"ish" OF Changed for collins
03-05-2011, 10:51 PM | #2 |
Major nutz
86
Rep 1,489
Drives: '09 n54 e92xi, 6mt, kw v3
OK, I was going to just suggest "Search this Forum", type in "BBK", and click "Go". But I'll take it a step past that just to answer my own nagging question I've had for a long time, "Is it really any different from the 'i' ?". So I just spent about 30 minutes comparing 335i brake parts to 335xi parts over at realoem.com with Firefox and IE (to make sure there was no HTML cookie or session BS) and I found absolutely no differences between the two in regards to caliper part numbers, the (probably most important) brake carrier (aka brake bracket) part numbers, and rotor part numbers (i.e. their diameters!!! which by the way are 348mm x 30mm for front and 336mm x 22mm for rear), nor therefore any price differences either, between 335xi and 335i. (I did not check between 328xi and 328i, sorry.) Thus I say whatever fits on i will fit on xi. However, the inner barrel diameter of your wheel may make a difference. So there may be an 18" or even 19" wheel requirement with the particular BBK of your lustful and money wasting desire.
Check it yourself and start here: http://www.realoem.com/bmw/select.do...0090600&arch=0
03-05-2011, 10:59 PM | #3 | |
E90Post Supporting Vendor
25
Rep 697
if alcon makes a set for the 335 xi they would be my first choice, i had them as well as brembo on my a4/s4...and i would definitely lean towards alcon |
03-06-2011, 11:10 AM | #4 |
Rep 689
im already running 19's so wheels aren't an issue. the issue is the tiny brakes and rotors inside the wheels, i just want to be 200% sure before i go and drop 2.5k+ on something that isn't going to fit
03-09-2011, 03:48 PM | #5 |
109
Rep 1,801
I tried fitting the front stock brembo 135i brakes on my e90 330xi and they don't fit. You could make them fit by fabricating a custom bracket, but i'm still not sure if i want to go through the hassle, let alone safety issues.
However, i know they fit on the e90/e92 328i as some local members (ie Hedges/Kriston) have had success, but not 100% sure about xi. |
03-09-2011, 04:52 PM | #6 |
/r/trees
50
Rep 875
03-09-2011, 04:54 PM | #7 |
Rep 689
i wouldnt trust making my own bracket for brakes. ive been doing some searching and have mostly come up empty. id really like to figure something out, i might just call Brembo/ stoptech and see if they have anything available
03-16-2011, 01:28 AM | #8 |
rallyroad.net
23
Rep 113
As soon as I get an E90, I'm making a BBK for it! I might go out and purchase a spindle to get going on this right away. I haven't been this excited about getting another car in a long time.
