Procede boost fluctuation
03-07-2011, 06:06 PM | #1 |
Rep 1,039
While driving tonight my car started having the boost go from 2-17psi it was all over the place. Shortly after I got a half check engine light??? WTF. Also I could hear the wastegates clicking a lot. About 5 more mins of driving that car is back to normal......any ideas???
03-07-2011, 06:09 PM | #2 | |
1748
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
03-07-2011, 06:24 PM | #3 |
Rep 1,039
I'm running the 1-21 maps you sent me with my unit. On install I got a really hard start with a half check engine light. The car reset itself and was perfect. That was Friday night.
03-07-2011, 06:53 PM | #4 |
1748
Rep 17,960
Drives: A Lot
It's not terribly abnormal to get a hard start/engine light upon installation since often the DME doesn't fully go to sleep before it is unplugged. The boost oscillation thing is something else I think. I've seen it reported once before but I have not been able to recreate it. If it happens again, can you switch to valet mode (map0) and see if the problem persists? That will tell me where to look if it is indeed a traceable problem.
03-07-2011, 07:08 PM | #6 |
1748
Rep 17,960
Drives: A Lot
Doesn't really help without a datalog to go with it unfortunately.
03-07-2011, 07:23 PM | #8 |
1748
Rep 17,960
Drives: A Lot
03-07-2011, 07:34 PM | #9 |
Rep 1,039
Map 1 and map 2 are only making 2psi at most now. Map 0 has boost fluctuation. Would the wastegate compensation have anything to do with anything? At idle I can hear the wastegates click alot. But only on map 1 and 2.
03-07-2011, 07:39 PM | #10 |
Rep 490
Drives: 335i
17psi?
Shiv whats the max boost on map 1?? |
03-07-2011, 07:44 PM | #11 |
1748
Rep 17,960
Drives: A Lot
Max allowable boost is 16psi. Don't worry though.. that 17psi reading on the Procede boost display read from the intercooler pipe, in FRONT of the throttle body. It is being caused by throttle closures, not from actually running high boost. Actual boost is probably below 10psi in the OP's case.
Shiv |
03-07-2011, 07:46 PM | #12 |
1748
Rep 17,960
Drives: A Lot
If you can email me a datalog (shiv@vishnutuning.com) I can try to make sense of what you are seeing. Without it, Im just guessing. Not something I can figure out here. And it should have nothing to do with wastegate compensation as everything is completely disabled in valet mode.
03-07-2011, 07:50 PM | #13 | |
Rep 490
Drives: 335i
Also can I limit the boost to 13 psi peak if I wanted to? |
03-07-2011, 07:52 PM | #14 | |
1748
Rep 17,960
Drives: A Lot
Shiv |
03-07-2011, 07:54 PM | #15 |
Rep 1,039
Thanks shiv. I guess I'm just very frustrated right now. I'll do what I can in the am. I'm in limp mode now anyway. Map 0 runs just like map 3. Going home for the night.
03-07-2011, 07:56 PM | #16 | |
Rep 490
Drives: 335i
Idk if you saw the thread under this one with the procede code ckearing, I got a response from Rob but maybe you had something to add? But thanks anyways |
03-07-2011, 08:05 PM | #17 |
1748
Rep 17,960
Drives: A Lot
03-07-2011, 09:09 PM | #18 |
Rep 75
Oddly this is exactly what happened to one of my customers ride.
We tried to remove procede and the wg clicking is gone. The car does have the old harness though, I flash the unit v4 and everything works like a charm. |
03-07-2011, 10:33 PM | #19 |
Rep 1,039
I have the old harness with update that was posted. I followed the directions to the "T". My procede was purchased in august 2010. When my car was the V4 I NEVER had one single issue!!!! I was thinking about reverting back too! ???????
03-07-2011, 10:35 PM | #20 |
Rep 1,039
also I notice that that wg clicking is not all the time. when the clicking starts the cars starts to have its issues. I just went up to the store and the car was fine.....the wg rattle was gone, but i really didnt have to go far. Its just so weird!!!!
03-08-2011, 06:27 AM | #21 |
Rep 75
My situation is a bit different, the car runs fine upon start cold and drive normally, but if drive aggressively, the wg would start clicking and thats when the boost starts to range from 3 to 8psi or so, and it won't go away.
There was no CEL though. |
03-08-2011, 08:00 AM | #22 |
Rep 1,039
but it sounds similar too. minus the cel. But the whole driving normal thing is the same as my car also. Everything is fine till i want to get on it. and the boost does exactly what yours does as well.
