Procede v5 Wastgate Position
03-10-2011, 01:00 PM | #1 |
Rep 34
I was just curious people who have Procede to get rid of wastegate rattle, what is your wastegate position set to?
Mine is at 40% now and it still rattles really bad when i start up the car It's quite embarrassing. I'm out of warranty btw. |
03-10-2011, 01:16 PM | #2 |
Rep 859
I set mine as low as 30% to get rid of it. Luckily, I was able to get my turbos replaced and now have it set to the default 90%.
2007 335i SG Coupe
2009 128i AW |
03-12-2011, 06:14 PM | #5 |
PSI
15
Rep 349
It seems like I get much better cruise MPG with WG set at 30% vs 90%. Seems like at 80-85mph with WG at 90% I'm almost cruising with 1lb of boost or so. WG more open at 30% naturally builds boost later, and makes the exhaust come alive. On the other hand, the responsiveness of the 90% setting is like an NA car.
2011 335d, M-sport, Alpine White, Nav
03-13-2011, 07:29 AM | #11 |
Rep 45
I had to set mine at 30% to get rid of the rattle, but it doesn't go away until the engine warms up. As I understand it, the PROcede WG fix doesn't kick in until the oil temp is > 160 degrees. You may need to confirm with Shiv on this, but I think he's planning on implementing the WG fix immediately on start-up with a future update. I'm with you that the cold start rattle is a bit embarassing.
'07 E92 335i, 6AT, ZSP: PROcede V5, CP-E FMIC, RR Catless DP's, Quaife LSD, STETT CP, FORGE DV's, AFE DCI.
03-13-2011, 09:56 AM | #12 |
Rep 224
Drives: '18 M2
Same here, the rattle was horrible on my car, sounded like a loose exaust heat shield. They replaced both turbos.
M2 LCI bone stock
Recently gone, i3 on H&R Springs Long gone, Le Mans Blue X1 xdrive35 M-Sport - Alpina TCU flash - HR springs - Catless dp - JB4 ST2 - CAI -- Alpine White 2007 335i E92 - Procede v3 Stg 2/3 custom - VRSP 3" DP - Stett charge + Forge DV - Stett CAI - CXracing IC |
