Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > H&R+Bilstein or Eibach+Koni Impressions for xi
View Poll Results: 328ix Suspension Lowering Choice
H&R/Bilstein 29 40.85%
Eibach/Koni 42 59.15%
Voters: 71. You may not vote on this poll
      03-17-2011, 07:08 AM   #1
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Arrow H&R+Bilstein or Eibach+Koni Impressions for xi
Vendors with experience encouraged to answer
OK, just bought a new set of the 18" Staggered MiRo 942's (BMW 313 Reps) & non-RFT tires to replace the factory 17's/RFT's on my 328ix E92
Time to also lower the car and get rid of the God awful 4x4 truck look. Not looking to go to extent of coilovers - just springs/shocks.
From all my reading, it appears that most go with either:
H&R Sport Springs/Bilstein Sports
H&R Sport
#50494-2
Bilstein Sports
Front Left: 35-142478 (F4-VE3-E247-H1)
Front Right: 35-142485 (F4-VE3-E248-H1)
Rear Left/Right: 24-120425 (F4-BE5-C042-H1)
Eibach Pro Kit Springs/Koni Sports or Bilstein
Eibach Pro
Koni Sport
Front Left: 8741-1535LSport (apparently not available)
Front Right: 8741-1535RSport (apparently not available)
Rear Left/Right: 8240-1236Sport
#1 Eibach does not list an ix specific spring, yet I know several members have used them. For those that are running Eibach's on E92 ix - are you using the 328i Coupe #2091.140, 328i Sedan #2085.140 or 328i Vert #2099.140 (which I found some vendors list as correct for 328ix Coupe also)?
#2 From member reviews, I gather the H&R springs offer bigger drop-but the ride is harsher, while Eibach's are less drop with comfortable ride. Is this the consensus?
I never intend to track the car - just normal every day driving. Roads here in Western PA are definitely not the best, but the non-RFT tires should soak up some of the shock over the RFT's.
Would you recommend H&R/Bilstein, Eibach/Bilstein for my application & why (if you have direct experience)...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      03-17-2011, 08:10 AM   #2
MassBimmer
MassBimmer's Avatar
306
Drives: 2023 i4 M50
2009 BMW  [9.24]
Seeing as that Koni doesn't offer shocks that fit the xi, this thread is essentially moot.
      03-17-2011, 08:21 AM   #3
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Ah, I beg to differ with you - they make yellows, just no FSD. Direct from the Koni site:
http://www.koni-na.com/cat_search.cf...27&submit.y=11
Otherwise, where would I have got the P/N's to post?
So now we're no longer 'moot'
      03-17-2011, 08:30 AM   #4
MassBimmer
MassBimmer's Avatar
306
Drives: 2023 i4 M50
2009 BMW  [9.24]
No they don't, they only make rear shocks for the xi, they do not make fronts. You can run these in the back and stocks in the front but the Koni yellows won't fit up front.
Dinan offers this set up for 335's only. Must be a reason they don't offer for 328.
      03-17-2011, 09:21 AM   #5
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Well, then either the Koni site is incorrrect, or they need to be more specific with their application details.
This is what they state:
BMW 08-11 3 Series - Sedan/Coupe, Xi AWD Models - Sport (Yellow)
So one would assume by that statement that it includes all 3-series sedan & coupe XI AWD models - and they list part numbers for the fronts...
I sent them an email requesting clarification
      03-17-2011, 10:48 AM   #6
MassBimmer
MassBimmer's Avatar
306
Drives: 2023 i4 M50
2009 BMW  [9.24]
If you click on the application, you're only able to order the rears, you can't order the fronts
      03-17-2011, 11:40 AM   #7
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
OK, well I never went that far because I would never buy directly thru them - you are correct, only the rears come up.
Which is even stranger because I have found other online vendors selling Koni sets listed specifically for the 328ix that include all (4) shocks and even list the part numbers for the fronts the same as numbers on Koni site.
Wonder what they give you then if they aren't available-sounds like some fraud going on there...
That's crazy, why go to all the trouble of making part numbers & listing them for an app if they don't actually have them? Are they something that is in process?
At any rate, I'm not going to run lowering springs on factory shocks, so I guess that changes the scope of my question/poll slightly - edited thread.
I'm still interested as to Koni's explanation
Thanx
      03-17-2011, 12:10 PM   #8
MassBimmer
MassBimmer's Avatar
306
Drives: 2023 i4 M50
2009 BMW  [9.24]
Nah, if they don't have them now they'll never have them. I'm running H&R Sports on stock shocks and, to be honest, the ride is pretty good. Obviously harsher than stock but well within tolerance. If you're considering shocks, I would recommend springing for them. Suspension installs are pricey and you don't want to have to do it twice.
      03-17-2011, 12:15 PM   #9
henry418
Drives: 2016 BMW M3
go with Eibach + Koni
      03-17-2011, 12:29 PM   #10
MassBimmer
MassBimmer's Avatar
306
Drives: 2023 i4 M50
2009 BMW  [9.24]
sigh, thanks for reading the thread
      03-17-2011, 01:29 PM   #11
ollie
Drives: 2013 535i Xdrive M Sport
The sticky at the top of the XI section has allthe info you can choke down on suspensions for the X drive cars. Turner is running a sale of 10% off for the month of March on Bilsteins...mine will be shipping soon and will be matched to a set of Eibachs. I probably would have used Koni but as has been discussed ad nauseum on these boards, there are no Konis for the front of the 335 X drive cars, nor will Koni ever build one, so it seems.
      03-17-2011, 02:07 PM   #12
Adj5633
Adj5633's Avatar
Drives: Screws
I am thinking about lowering, and if I do I am 90% sure to go the bilstein/H&R route.
It makes sense to me, the components are designed for the xdrive system, although it seems it wont get rid of the rake. But I'm going more for the tighter feel of the car than the look.
Plus they are on sale: can you say win?
Also, I'm still unsure because I want to keep my style 284 wheels (with ps2's) and am hoping it won't look cheesy... But I digress lol
hope that helps
      03-17-2011, 02:45 PM   #13
henry418
Drives: 2016 BMW M3
sigh, thanks for realizing the sarcasm
      03-19-2011, 03:41 PM   #14
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
OK, I get the deal with the Koni's. So since I won't run factory shocks with lowering springs, my only option is the bilsteins.
Still doesn't answer my question #1 as to what Eibach springs xi drivers are using?
I realize the rears are the same between i & xi but fronts are different.
So Ollie, did you just buy the i Pro Kit for your 335 since they don't list a xi kit?
The sticky is very general regarding the Eibach springs - it states Pro Kit - OK, that's great-what P/N? They don't make one for xi - so I'm looking for what xi owners went with & their impressions/experience as to how they worked...
Guess I'm leaning toward the Eibachs because the amount of lowering is not as great as the H&R's & seems peole state the ride is 'gentler' on crappy roads - but I hesitate to buy any part that is not made specifically for my application without hearing actual results.
      03-19-2011, 03:52 PM   #15
henry418
Drives: 2016 BMW M3
Many people are using the Eibach Pro-Kit for 335i (not xi) without any problems. The part number is 2092.140
This guy recently installed it with no problems:
http://www.e90post.com/forums/showthread.php?t=502349
Other people:
http://www.e90post.com/forums/showthread.php?t=249243
I will also be installing Eibachs on tuesday. I'll post a review and some pictures of the drop after it settles
And yes, they will be gentler than H&R sports because they have lower spring rates
      03-20-2011, 11:27 PM   #16
Patsfan123
Patsfan123's Avatar
Drives: 2007 328xi Coupe
Other people:
Even people with E92 328xi's are using the Eibach 335i springs? I see there is a specific part for E92 328i's
2007 328xi Coupe | TiAg | Steptronic | Premium | Sport | Nav | Comfort | Cold Weather | BMW Sport Exhaust | BMS PBX | Euro Airbox w/ K&N | Eibach/Bilstein | RDash LED License Plate
      03-21-2011, 03:58 AM   #17
henry418
Drives: 2016 BMW M3
Sorry about that, forgot to say. Seems that 328xi people use 328i springs instead of 335i springs.
      03-21-2011, 05:11 AM   #18
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Exactly what I was questioning. I see a couple using the i springs, but they were all 335xi
So if you can use the i springs for xi:
328i E92 --> #2091.140 Front 1.0/Rear 0.8
328i E90 --> #2085.140 Front 1.2/Rear1.0
335i E92 --> #2092.140 Front 1.0/Rear 0.8
335i E90 --> #2092.140 Front 1.4/Rear 1.0
Funny how 328 uses (2) different P/N's based on whether E92 or E90, while 335 uses same P/N
And 335 P/N yields (2) different drops depending on whether used on E92 or E90 even thought it is supposedly the same spring. Must be vehicle weight?
To be safe I guess 328ix E92 should go with 328i E92 springs - I wonder what would happen/what would be drop if 328i E90 springs were used on 328ix E92?
      03-21-2011, 03:11 PM   #19
Patsfan123
Patsfan123's Avatar
I PMed phrozenstone who had the Eibach/Bilstein setup before and he confirmed he used 328i E92 --> #2091.140 Front 1.0/Rear 0.8 for his 328xi E92. That is what I will be ordering. Thanks to him for clearing this up.
      03-21-2011, 03:56 PM   #20
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Great! This is what I'll be going with also then...
Thanx to all that contributed
      04-18-2011, 02:31 PM   #21
ChrisJadesFireF82
ChrisJadesFireF82's Avatar
21
Drives: 2016 BMW F82 M4
whats the price on the Eibach/Bilstein setup?
      04-18-2011, 09:45 PM   #22
BMW1986
BMW1986's Avatar
Drives: 11 M3 E92 ZCP JB/PS & BLK
Been running H&R and Bilstein; no complaints at all. LOVE IT!
11 E92 M3 DCT Jerez Black ZCP...Eisenmann, Dinan, Fabspeed, IND, LUX
