Compression test - 1st in 3 years :)
03-31-2011, 09:28 PM | #1 |
273
Rep 5,876
Had a compression test done at BMW the other day. Numbers look great, all cylinders close to each other. This was done with a BMW tool following their documented procedure. End result is this tiny card about 1.5"x1.5" in size thought you might find it interesting to see
03-31-2011, 09:35 PM | #2 |
Rep 3,460
Roughly speaking the lowest cylinder was about 18.2 bar which is roughly 264psi
and the highest one was 19.5 which is 282psi. I don't know what the spec is suppose to be, but they all seem high to me. I am used to seeing pressures in the 150-180 range on all the cars I ever did. |
03-31-2011, 10:00 PM | #4 | |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
04-01-2011, 10:49 AM | #5 |
Rep 759
Drives: '11 E92 M-Sport
I'm used to seeing 180-200 for lower compression turbo cars (8-9:1).
If that chart is including atmospheric pressure of 1 bar, the numbers would be in the 240psi range mostly. Probably good for a higher compression DI car. |
04-01-2011, 11:54 AM | #7 |
Rep 1,179
no matter the numbers (hi or lo) if they are all consistent thats what matters.
if the concern is carboned up combustion chambers, it would show in areas of drivabilty |
04-01-2011, 12:44 PM | #8 |
Rep 7,377
Great work dzenno! Good reference point.
04-01-2011, 06:30 PM | #10 |
273
Rep 5,876
Recommend everyone especially those with upgraded turbos or those about to get them to test your engines and see where you stand..in case numbers don't look right I'd stay away from further modding and trade your car in
