BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > Service reset DIY
      03-13-2007, 04:21 AM   #1
mikem
83
Drives: Z4M
Service reset DIY
Guys I looked everywhere (maybee not hard enough ) for a DIY service reset for E90 but couldn`t find one. So decided to try the E60 DIY which wasn`t too far off. I realise most cars are still under warranty but I will use this to replace my own brake pads and microfilter instead of being fleeced by the $tealers.
Step 1
Insert key into slot
Step 2
Press start/stop button without depressing clutch/brake and wait for the service reminder to dissapear.
Step 3
Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again.
Step 4
You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items.
Step 5
When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done
Step 6
You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
Sorry if this a re-post guys but like I said I couldn`t find it anywhere.
I accept no responsibility if you break your car, this is done at your own risk.
      03-13-2007, 05:13 AM   #2
ski360
ski360's Avatar
25
Drives: 325i
Good to know
      03-13-2007, 07:50 AM   #3
txusa03
Drives: TS330iPPSP6MT
admin-stickies this pls (if you have not already done so ) ...there was another thread on this but this thread seems to give more step by step detail. Thanks.:rocks:
under construction!
      03-13-2007, 10:46 AM   #4
worlina
Chief
worlina's Avatar
Drives: 2016 BMW X5 xDrive 35i
Great post. Thanks!
      03-13-2007, 07:13 PM   #5
epiphone3
111
Drives: 2013 BMW X3 35i
great job! This will be good for me later when it comes to microfilter swap
      03-13-2007, 07:24 PM   #6
BMW_E90
BMW_E90's Avatar
57
Drives: 325i
make this a sticky please admin!
      03-13-2007, 11:09 PM   #7
montreal_bimmer
OEMconcept
montreal_bimmer's Avatar
Italy
174
Drives: BMW
2006 325i  [10.00]
very good post, should be made a sticky
      04-07-2007, 11:52 AM   #8
epiphone3
111
admin please sticky
      04-08-2007, 11:12 AM   #9
calvino
Drives: had e90, 330i mystic blue
2006 e90 330i  [0.00]
you are missing something, that menu is LOCK to unlock it, you need to go in the menu to option 19 and is going to said "lock on" and then "code 00" to find your code you have to add the last 5 digits of your VIN, my unlock code is 20 then you nove the "code 00" to "code 20" then that menu will have many options like oil temp, cabin temp, real speed, time that said how many hours you have driven and the last one said "RESET" that's the one that you click and it will reset your service
E90 Mytic Blue 330i 07-20-2006. 05-17-2011
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML
      04-08-2007, 03:11 PM   #10
Art Man
England
Drives: 320D SE
I tried this and all it reset was my MPG, average MPH, distance travelled etc, but not my service.
      04-08-2007, 03:41 PM   #11
ironic
ironic's Avatar
Drives: Jet Black 335i
great post
Widebody 335i Project Car BUILD | PHOTOSHOOT
      04-19-2007, 09:53 PM   #12
DrewKo
DrewKo's Avatar
44
Drives: 335i Montego Blue Saddle Brown
2007 335i  [0.00]
Didn't work for me either. I get the German writing and no other options; tried it tons of times.
      04-21-2007, 07:03 AM   #13
mikem
83
Drives: Z4M
I have no idea what you`re talking about, honestly
As for the others follow the instr. carefully and it will work.
A word of warning `tho if you don`t want to alter the date of next service, you`ll need to change the date in your car to the date when the last service was done. Otherwise the computer will aytomatically change the date to 2 yrs from todays date. (hope that makes sense)
      04-24-2007, 09:40 PM   #14
Nice E90
Drives: '06 325i sport, on PS2's
I can confirm this works perfectly, when you follow the instructions given.
I do have a question on the "next service date". My computer did change the next service to 2 years from now. Not a big deal, I service my car when I want to, I don't care about BMW's free service. But, could you explain again about changing the computer's date to fix the 2 year service thing?
Thanks
      04-26-2007, 04:16 PM   #15
mikem
83
Drives: Z4M
Nice, to set the "next service date" to a desired date, choose your date, deduct 2 years, then before you reset the service alter the date in your settings to that date.
      05-01-2007, 03:37 PM   #16
cgnahc
cgnahc's Avatar
Drives: TiAg E90 ZSP
This DIY is a keeper. Can you list everything that can be reset? List it as a reference here. (milkem and calvino "code 20")
      05-03-2007, 09:23 PM   #17
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Added to DIY master list - http://www.e90post.com/forums/showthread.php?t=1721
Thanks for sharing.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
      06-15-2007, 01:51 AM   #18
mikem
83
Drives: Z4M
**UPDATE**
The service indicators can still be reset even when the inspection symbol appears (car on a lift)
All you have to do is insert key hit the start button and wait for the red car on a lift to disappear (about 10-15 secs) before holding down the trip reset button.
      07-19-2007, 08:35 AM   #19
phantom330
phantom330's Avatar
18
Drives: e93 335i
Originally Posted by mikem View Post
**UPDATE**
I just picked up my car yesterday, and I have that inspection symbol showing up, what does that mean? Can I reset that?
      07-29-2007, 12:23 PM   #20
bluenwhite
Drives: BMW 330i
Hmm, I tried it, before I get the service menu, it shows me the (ABS) in yellow!! Do you have any idea what does it mean?
      08-03-2007, 08:56 AM   #21
Motofish
Drives: E90 320i
Changed my microfilter today and followed the instruction. Works perfectly. Thanks for the tip.
      08-29-2007, 01:53 PM   #22
apollo
Drives: F82 Sakhir Orange
I think that may happen if no service is due, thats what happened to mine when I tried it when a service wasn't due.
