TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Jacking Up E92
      03-13-2007, 11:49 AM   #1
stevew
Drives: 2009 E92 325i M-Sport
Jacking Up E92
I need to take wheels of my E92 325 to clean up & repaint the hubs which are showing slight rusting that is visible thro' the alloys & is annoying me :mad: . Plus I always like to get the rims of a couple of times a year to give them a proper clean
As the E92 has RFT's & hence no jack has anyone got any tips/advice etc. The handbook just shows the jacking points. I've got access to a trolley jack. I believe BMW do a jack kit (from reading posts from the US) but I suspect it's dear for what it is.
      03-14-2007, 03:17 AM   #2
peppernick
51
Drives: M4 vert
A jack is a jack. Just about any that can take 1.5 tons should do.
      03-14-2007, 03:24 AM   #3
ChrisMWard
United Kingdom
14
Drives: E93 320d M Sport, E81 116d SE
2006 120d SE  [0.00]
2007 335d A M Sport  [0.00]
1998 M3 Evo  [0.00]
2002 330d Sport  [0.00]
2004 330d Sport  [0.00]
The wheel chock that was supplied with earlier BMs was a also a very useful item and good safety feature when jacking up your car.
I again like to take the wheels off every now and then to give the inside of the rims a good clean.
Regards
Chris
Previously: 2007 335D MSport E90 Le Mans Blue, 2004 330D A Sport Silver Grey, 2002 330D A Sport Saphire Black, 2001 320D SE Touring Titanium Silver, 1998 M3 Evo Techno Violet, 1996 328i Sport Montreal Blue, 1994 325i Coupe Red, 1989 325i Sport 2 door Dolphin Grey,1986 325i SE 4 door Lachs
      03-14-2007, 04:46 AM   #4
stevew
Did you put anything in the plastic "insert" where the jack fits to prevent damage?
      03-14-2007, 05:23 AM   #5
peppernick
51
Drives: M4 vert
The plastic buffer/insert is 10 pence a piece. I just change them if they get too deformed.
      03-14-2007, 06:00 AM   #6
stevew
Won't break the bank then . You don't know the part no by any chance so I can just go into the dealers & get them when needed?
Cheers
Steve
      07-12-2008, 12:25 PM   #7
YvesD
Lamininist
YvesD's Avatar
United Kingdom
84
Drives: Carbon Black X5M
Thats handy to know, Ive wrecked mine today jacking the car up for an oil change.
Another thing, the trolley jack lifting cup dug into the BMW insert on one side and I had a tough job freeing it off !
Regards
Yves
      07-12-2008, 06:50 PM   #8
tmarshall57
tmarshall57's Avatar
United Kingdom
56
Drives: F10 530d M Sport, E87 118d M
I use a piece of softwood to insert into the jacking point. I bought a length of wood from B&Q which only requires cutting to length. I also put a piece of thick carpet on the lifting part of the trolley jack.
Others have bought purpose made aluminium blocks (from guys in the US)
Tony
F10 530d M Sport, September 2012 Individual Amazonite Silver, Oyster Dakota Leather, Auto, Nav Pro, Bluetooth + USB Devices, Expanded BMW Online, Comfort Seats, Sunroof, Sun Protection Glass Individual Satin Walnut Honey Brown Trim Interior Inside/Outside Mirror with folding and autodip, M Rear Spoiler
      07-13-2008, 04:14 AM   #9
ed335d
ed335d's Avatar
United Kingdom
141
Drives: E92 M3
I just cut a block of wood and put in the cup - worked a treat. Did my hubs a couple of months ago for the same reason:
I used:
Wire Brush
240 grade paper (wish I'd used something a bit coarser)
White spirit (cleaning after the rubbing)
Halfords paint prep wipes (after white spirit clean)
Halford very high temperature paint, black (decided against silver as think it may show the brake dust & general road grime)
Medium & small brushes
Cellulose thiners (for cleaning the brushes)
Lots of elbow grease!
I've not got the steadiest of hands, so close up it's not as perfect as I like - but looks miles better once the 230's are back on.
Before
After rubbing & cleaning
After painting
Wheel back on
Decided to go with black so the brake dust doesn't show. Still look as good as the day I did them!
      09-21-2008, 01:45 PM   #10
acerboo
England
181
Drives: e92 335d lci
you can buy a proper jack kit from bmw for £90 comes with a torque preset 17mm socket and handle fits perfectly and wont damage your car
