Question regarding rims for my 2011 335Xi Sedan
04-07-2011, 09:38 AM | #1 |
Rep 88
Hi,
i have a 2011 335XI sedan with stock suspension. planning on putting the following rims/sizes on -19x8.5 +33 fronts 225/35/19 -19x9.5 +33 rears 245/30/19 will i be okay? |
04-07-2011, 09:55 AM | #2 |
Rep 7,433
Why are you running such stretched tires with normal offsets?
EDIT: you can't run that rear tire size with the front you have listed anyway, it's 1.5% difference in rolling diameter...you want to stay below 1% |
04-07-2011, 10:28 AM | #3 |
Rep 88
massbimmer: actually this is for a set of rims i want to buy... and these are the tires coming with the rims...... i'll probably have to replace the tires sooner or later anyway... so what tire size should i get so that it'll run normal... keep in mind i am not planning on lowering my car...
also... if the difference in rolling diameter is 1.5% what is the negative thing about this? thanks for your help. |
04-07-2011, 10:28 AM | #4 |
96
Rep 1,652
Those tires are too thin. Youll need like 245/35 front and 265/30 rear.
Current: 2019 F90 M5 Competition
Previous: 2016 F80 M3 Past: 2013 E92 M3 Past: 2011 E92 335Xi |
04-07-2011, 10:51 AM | #5 | |
Rep 7,433
I think you'll be ok with 235/35/19 up front and 265/35/19 in back. If you're not lowered and are on standard xDrive suspension, you shouldn't have any rubbing issues |
04-07-2011, 01:28 PM | #6 |
Rep 88
hey guys, thanks for all the replies... what if i want to leave the tires up front the way they are since they still have lots of tread but the rears i will change...... what can i change them to you ensure that the rolling diameter is less than 1%?
also is it highly probable that it will damage my transfer case on the XI? the rears only have 40-50% tread left... so i dont really want to waste them either. let me know guys.. thanks a lot again. |
04-07-2011, 02:07 PM | #7 |
Rep 7,433
I'm pretty sure that spending $300 on new rear tires is a much better option than f'ing up the AWD system on your $50k vehicle just to save a few bucks.
There's a calculator in the wheels/tires section. You would want to pair a 255/30/19 tire with the 225/35/19 fronts. |
04-08-2011, 09:12 AM | #9 |
148
Rep 1,728
Yes, these would be the correct sizes. These are actually the sizes that come from the factory w/ 19s
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
