Suspension Help!!
04-12-2011, 07:23 PM | #1 |
Rep 7
Drives: 325XI
Suspension Help!!
Just put H&R coils on my car and I'm hearing a loud clunk for both front struts...also im only sitting at 25in in the rear and we took the helpers out. just seems to be sitting kind of high in the rear still after an alignment and a week of settling. any suggestions?
04-13-2011, 11:32 AM | #4 | |
290
Rep 28,154
did you drop the car really low? you may have unloaded the spring tension and thats what can be causing your clunking, either that or check to make sure you tightened the top nut holding the strut hat on tightly, any slack will result in a clunk sound. sway bar end links being loose can cause it too |
04-13-2011, 04:47 PM | #5 |
Rep 7
Drives: 325XI
I did drop both front and rear coils all the way down. it only clunks at low speeds turning either direction. The person who put them in said he thinks the strut bearings may have went bad. Im pretty much a newb when it comes to some tearms. i can put up some pics this weekend.
04-13-2011, 04:49 PM | #6 |
Rep 7
Drives: 325XI
05-16-2011, 05:18 PM | #7 |
Rep 7
Drives: 325XI
Bump
11-10-2011, 06:52 PM | #8 |
Highbrowdropout
Rep 30
Drives: 2008 e90 m3 slick top / cloth
Fix binding by Making coil spring silencers, they work awesome if its really just coil binding! I used my buddys cheapie car just as an example but have it implimented on kwv2's on my 2006 e90 sedan.
You will need to figure out where the binding is happening and place your silencer in those places. You could get the tube at any hardware store for 49 cents a foot! |
11-10-2011, 07:35 PM | #9 |
Highbrowdropout
Rep 30
fix that spring binding
Thats not true, follow my guide below and live in silence! I promise you dont have to suffer from spring binding and its so easy to fix!!
