Proper Tire Pressure for Increased (+5) aspect
04-14-2011, 07:45 PM | #1 |
Rep 4,121
All,
I am running +5 greater aspect than oem (225/45/18 vs 225/40/18 and 255/40/18 vs 255/35/18) The tire pressures for the above "standard" fitments would be: 35 front and 41 rear I have them at 34/38. what do you think? |
04-15-2011, 01:19 PM | #3 |
BimmerPost Supporting Vendor
2042
Rep 25,989
225/45 and 255/40 are tall sizes. I do not recommend running these sizes since it may cause rubbing issues during compression or a full cabin.
Im a bit confused on what the additional tire pressure would do if the wheels are 5% over the recommended rolling diameter. -Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
04-15-2011, 03:52 PM | #5 |
55
Rep 1,495
The tires volume has nothing to do with the psi. Psi is psi. Running 32 psi for example will be the same, it'll just take more air to get it to that psi on a larger aspect ratio tire.
04-15-2011, 08:25 PM | #7 |
NHTSA Nazi
28
Rep 1,983
You do know that changing the overall rolling diameter of the tire can be considered odometer fraud.
Odometer fraud is one of the few things that will void your entire warranty and may cause your title to be branded as "true odometer reading unknown." |
04-15-2011, 09:54 PM | #9 |
Rep 2,643
The higher aspect ratio tyre will typically have a higher load rating. This makes it possible to lower the tyre pressure to improve the comfort, but there's a trade off in ultimate performance as the tyre deforms more under high loads. As far as performance and handling are concerned, I think you should keep the same pressure as you would have for a lower aspect ratio tyre.
04-17-2011, 12:18 PM | #10 |
Converted
Rep 18
I have done quite a few searches and this is the only thread I can find on tire pressure on an 18" rim. So please excuse my "thread jacking".
I just purchased some NON runflat tires. G-Force tires for somer. So far I love them but have that ongoing fear of getting a flat in the back of my head. The same day I had them put on the TPS light came on twice. We reset it both times and checked the pressure. All was fine. Hasnt came on in over 400 miles, so I'm assuming since I have the ABS type, the computer needed to learn the new tires? Also what air pressure should I have in these tires? Tire place said 33/35 because thats what the car says, but I feel it may need higher due to the softer sidewall. What do you guys run?
'07 335i e90
04-17-2011, 02:12 PM | #11 |
Rep 111
Tire pressure really has no impact on if you will get a flat or not unless the tire is severely under inflated. It's acceptable to slightly increase tire pressures above the std. pressures. For sustained high speed driving on the autobahns in Germany they typically increase pressures 5 psi to reduce heat build up. A slight increase in pressure may improve steering response in some tires.
