Blown sub on 07 335i
04-15-2011, 01:42 PM | #1 |
Rep 23
hey guys...a friend spilled on the passenger side while driving, didnt inform me and now the sub's friend. where can i find a replacement? bmw quoted me something ridiculous so i dont want to consider it. i saw a lot of threads on earthquakes being the right fit etc but not sure if this is the right option. not really looking into upgrading the amp etc although i might consider it later down the road.
i have a logic7 system. |
04-15-2011, 01:48 PM | #2 |
Rep 2,396
I have exactly what you need
Woofer came out of 2007 M6. Enclosure will not fit e90 but the actual driver is exactly the same. Perfect if you blew out one of your old drivers (like I did). $60 shipped |
04-15-2011, 01:57 PM | #3 |
Rep 23
hmm
i'm not the biggest car handy person. i dont have most of the tools needed. mine is a e92 (coupe). i would want to find a fit that was the most convenient. dont want to cut out/drill/or makefit
any thoughts? |
04-15-2011, 02:02 PM | #4 |
Rep 2,396
It's quite simple actually.
* Remove the 4 bolts that hold the seat * Do NOT disconnect the seat harness, just lean the seat back. * Unscrew 8 (I think 8) bolts that hold the subwoofer enclosure and take it out * Unscrew 4 more screws that hold the woofer and remove it, put the new one back in * Put everything back in reverse. Where in MA are you? We're gonna have a meet in Westin there tomorrow. If you want come over and someone (I'll be busy coding cars) will help you. http://www.e90post.com/forums/showthread.php?t=505591 |
04-18-2011, 10:43 AM | #5 |
Rep 23
heya
hey man...are you in MA any time again?
i'm interested in your part. also on a side note i saw threads on the earthquake subs as a replacement. if i dont do anything with the existing amp, am i going to notice better sound than the stock woofer that got damaged? (sometimes i hear bass notes distort -if i have the bass set higher than normal and a bit louder) any ideas? |
04-18-2011, 12:18 PM | #6 |
253
Rep 7,089
Drives: '06 AW 330xi
You'll need a t50 torx bit for the seat bolts.
I think its a t20 for the speaker screws. And Phillips head for the grill....I think there is 6. |
04-18-2011, 12:19 PM | #7 | |
253
Rep 7,089
04-18-2011, 02:32 PM | #8 | |
Rep 23
onebadmofo, let me know about your replacement. i've got an infinity basslink II from my previous car. any thoughts on the easiest way to hook it up? power line etc... thanks! |
04-18-2011, 02:36 PM | #9 |
Rep 23
also...
do you think its worth hooking up the basslink with everything as is or dont bother with the basslink and just upgrade the two woofers to the earthquakes and hook it up to an amp?
04-18-2011, 03:21 PM | #12 |
Rep 2,396
Well you can always try and try to jam it in there. Plus you might want to change the other one too, not sure how the logic7 amp will handle two different woofers at the same time.
04-18-2011, 04:34 PM | #13 |
253
Rep 7,089
I think the op means put the bass link in the trunk....not under the seats.
The sws-8s didn't hit the way i wanted. They are only 8" woofers....they can only do so much. I blew them within 2 months with a Jl 500/1. I now have that Jl 500 powering a type-r in my trunk and have the stock l7 woofers externally amped. It sounds pretty good...not audiophiles quality but good enough for daily driving. If you like deep deep bass, get a trunk sub. Or try mounting that bass link unit. If you just want a mild improvement in low end, get the sws-8s and amp them. If you want tight mid bass and deep bass, upgrade the under seats to a better driver. From reading on here jenhert? And kicker sambas are good for mid bass. Trunk subs are endless....just set it up properly and you should be good. Ie proper box, power etc |
04-18-2011, 04:35 PM | #14 |
1911
Rep 13,104
Technic is the man to see
He will supply you with the speaker of your choice installed in the OEM housing
and also can give you technical support as to which speaker will work best with your system. He has many posts here and is located in Florida. There are some install threads in the DIY section and here as well |
04-18-2011, 05:03 PM | #15 | |
2288
Rep 13,001
Woofer housing pins (4): 61138364835. That's it. |
04-19-2011, 01:08 PM | #16 |
Rep 23
Technic, thanks so much for the reply! do you know what the price might be for the other two items? i'm just trying to gauge on how much this would total.
Also the kickers are a good deal? i mean do they sound good for the price? |
04-20-2011, 09:18 AM | #17 |
Rep 23
bit confused...
Hey Technic,
I have the logic7 system stock with no external amplifier hooked up. I was reading on of your posts (pasted below) Sound:do you still recommend the kickers over the earthquake? something i notice currently is the popping (occasionally) when the bass level and volume are set to higher levels, and was hoping to avoid this. I got my car in June and this is pretty much the first time I'm looking to make any changes and don't know much but hope to learn as much as I can. Thanks for the advice. Anyone else out there with any suggestions? |
Tags |
logic7, replace, subwoofer |
