2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes TPMS Sensors
      04-16-2011, 10:19 AM   #1
sequal
sequal's Avatar
22
Drives: BMW F10 2011
2006 BMW 330i  [0.00]
TPMS Sensors
hey guys,
I am switching wheels on my f10 with some 20". How do you transfer the TPMS Sensors from stock to new?
where are they located?
Thanks
2011 - F10 Alpine White / Black Dakota Leather/
2006 -E90 330i Sparkling Graphite/Black Leather
2004 -E46 Bmw 330CI Black / Black Leather/ Sports
      04-16-2011, 10:32 AM   #2
Vinfast
Drives: '14 550i M-Sport
They are screwed into the wheel. All the tire shop does is unscrew and put them in your new wheels.
      04-16-2011, 10:33 AM   #3
KRUZNM3
Drives: F80 M3
If you take your stock wheels to your wheel shop they will know what to do. Or if you want to buy a new set, you can PM Eric@pyspeed for a set!
[2016 Mineral White F80] [BBS LM] [Air Lift 3P]
https://www.instagram.com/kruznm3/
      04-16-2011, 10:35 AM   #4
sequal
sequal's Avatar
22
Do I need to take off the tires on the stock wheel to get to the TPMS?
thanks
      04-16-2011, 11:36 AM   #5
EV0LVE
EV0LVE's Avatar
42
Drives: F10 535i SG
yes, and you have to keep track where they came from so you can put them on the new wheel for that same corner. if it came from the front driver side then it goes back there and so on.
      04-16-2011, 06:18 PM   #6
sequal
sequal's Avatar
22
Thanks
      04-17-2011, 03:59 AM   #7
vngooi
Drives: F10
TPMS Sensors
This is something that I have not heard of....so the sensors are specific for each wheel?...what happens when you rotate your tyres....then one would have to take out the tyre, replace with the sensor from that specific tyre and then replace the tyre for rotation...does not make sense to me....
      04-17-2011, 12:31 PM   #8
cidair
cidair
cidair's Avatar
Sweden
83
Drives: BMW 435d xDrive
Is this really true???
I have problems with TPMS since I bought new BMW OEM 312 20" wheels ( including sensors ). Are they marked for each corner?
2016 435d xDrive
Previous:2019 M340i, 2014 335dx,2012 M5,2011 550ix,2008 M3,2007 330xd,2005 M5,2004 545iA,2000M5.
      04-17-2011, 03:48 PM   #9
EV0LVE
EV0LVE's Avatar
42
Drives: F10 535i SG
then you would most likely have to reset the tpms thru the idrive.
      04-17-2011, 03:52 PM   #10
EV0LVE
EV0LVE's Avatar
42
Drives: F10 535i SG
i know that when i had my wheels changed, the mechanic kept track of what tpms goes to what corner and i didn't have any issue after the new wheels were installed, coincidence? maybe. but i know what works.
cidair, you might just have to reset you tpms thru the idrive, i know we have that feature here in US, i never had the need to play with it though.
      04-18-2011, 02:26 PM   #11
cidair
cidair
cidair's Avatar
Sweden
83
I tried that, but it repetedly says TPMS failure ..see your dealer....
Today it warned 13 times in a 40 min drive on the freeway.....
2016 435d xDrive
      04-18-2011, 03:13 PM   #12
sequal
sequal's Avatar
22
what if you don't install the TPMS Sensors, will it warn every 10 min or once upon start up?
      04-18-2011, 04:50 PM   #13
Vinfast
No, the car gives no warning when they're gone. When I got my new wheels, my dealer had already removed all my TPM sensors and put them on the new wheels. Then they realized that one of the rims were bent from the factory so I had to wait about a week before I could get a new one. All they did was put my OEM wheels back on the car without the sensors and no warnings and no problems.
      04-18-2011, 06:34 PM   #14
sequal
sequal's Avatar
22
Really no error or nothing? I am debating if i should even swap them out or not.
      04-19-2011, 04:10 AM   #15
vngooi
Drives: F10
I would venture to say that there is no need to "remember" from which wheel the sensor comes from.
From the user manual, after a change of tyre or rotation or refill-up of tyre pressure, the reset is done through the TPMS module via the OBC. For the F10, there is an option to check that the TPMS is "active"...so, if presumably, if there is any fault in the sensors themselves, this should show up.
5post
