Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > (DIY) One little piece needed to enable our USA rear fog lights
      03-17-2007, 01:09 PM   #1
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
(DIY) enable our USA rear fog lights for E90 & E92
I took my light switch apart and discover that our switch has the ability for rear fogs, but there's one little piece needed/missing to activate it.
The switch is very easy to take apart.....just a few clips on the sides
(check other diy on how to take the light switch off)
Pic 1
Components of the switch
Pic 2
To have rear fogs…this is the piece we’ll need.
Another words, we’ll have to duplicate this
Pic 3
cut/clip the (yellow) circled areas will enable the rear fog button
(Edit)
Pic # 3 & 4......the button has "4" clips not 3...its placed inside so I took out the button and cut off the 4 clips on the button
Now taking out the button can be tricky....I used two small flat-head screw drivers to unclip the inside in order to release the button
Pic 5
Main Board – To activate the fogs (front & rear), the two rubber nipples must be pressed (left/right).
Now.....how do we duplicate the "white piece"
I use a plastic exercise grip.....cut it to the shape of the white piece and just glue a flat surface on top.
You can also use a plastic pen cap, legos, golf tee, or whatever works for you
Pic 6
OEM white piece - duplicate piece
The duplicate piece is longer because the white piece has a built in stop where as the duplicate don't, so it needs to be longer in order to hit the rubber.
EDIT: some new models/LCI already have the 2nd white piece inside.
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
grzes32.50
      03-17-2007, 01:30 PM   #2
HyperM3
Too many Alex's, from now on, call me Beaufort
Drives: See Sig
So can we just fabricate something to make it work? Isnt the buttons to activate the rear fogs different too?
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip
16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone)
07 335i(gone)
      03-17-2007, 01:36 PM   #3
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
just unclip (edit..."cut") the tiny little pieces holding the button (circle in yellow)
2006 325xi (Sold)
      03-17-2007, 01:40 PM   #4
HyperM3
Drives: See Sig
Rock on.
13 HD FatBob
07 335i(gone)
      03-17-2007, 01:42 PM   #5
uhaulball
Drives: e90 330xi
w000000tttttt.... weekend DIY. NICE FIND.
'06 bsm e90 330xi : 18" VMR CSL : KW V3 : GruppeM Rep Intake : UUC/Corsa Catback : Hartge Lip : ACS Roof Spoiler
OEM CF Trunk Spoiler : CF Emblems. Pillars. Mirror. Grille : LUXER12 led plate : V1 Hardwired : OG.longtran e90post sticker! circa 2005
      03-17-2007, 01:44 PM   #6
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
actually.....for those that already bought a german switch, give the extra piece to your buddy
it's really easy to do...takes 2 minutes
2006 325xi (Sold)
      03-17-2007, 01:58 PM   #7
uhaulball
Drives: e90 330xi
it's really easy to do...takes 2 mintes
wait, the german switch comes with an extra white piece?
      03-17-2007, 02:01 PM   #8
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
ok...
the USA switch has one (white piece)...the Germany switch has two (white piece)
each piece is the extension from the button to the main board
so for those that already bought the german switch (part # 61316932796), they can give away their piece from the old USA switch
2006 325xi (Sold)
      03-17-2007, 02:02 PM   #9
uhaulball
Drives: e90 330xi
then what extra piece are you referring to? are you saying the german switch owners can give the 2nd white piece away?
also, for me with the regular US version, if i do mod it, how can i make it so that the button presses inward, right now it doesnt go in at all.
      03-17-2007, 02:04 PM   #10
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
OMG...no one is reading...lol
look at pic # 3
use a razor blade and cut those clips off
2006 325xi (Sold)
      03-17-2007, 02:07 PM   #11
uhaulball
Drives: e90 330xi
dude i read perfectly.... nowhere did u say to cut it off lol. u said to unclip it. and then you said people with the german switch can give their "extra" piece away. i know the german switch has two buttons, hence two white pieces, but then when u said extra piece, i thought they had a spare white piece totalling in 3....
u made it unclear, now i know what you meant was, give the german switch in its entirety away, since this mod is easy to do!
but how would i fabricate a white piece? im still thinking.
      03-17-2007, 02:08 PM   #12
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
i need my coffee
but you know what i mean now right?
2006 325xi (Sold)
      03-17-2007, 02:10 PM   #13
HyperM3
Drives: See Sig
Ok, you lost me here. Wouldnt you need that piece for the second set of buttons on the resister board? If they give it away, they are left in the same place as us who have to fabricate something.
13 HD FatBob
07 335i(gone)
      03-17-2007, 02:17 PM   #14
uhaulball
Drives: e90 330xi
hyper, he meant give the german switch in its entirety away, since this mod is easy to do! we just need to figure out how to fabricate the small white piece. maybe we can create a small mold out of the white piece we already have. im just a little scared if i mess up, but if i do i could just buy a german part which is only 55 bucks anyway.
      03-17-2007, 02:17 PM   #15
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
nahhh
"so for those that already bought the german switch (part # 61316932796), they can give away their piece from the old USA switch"
2006 325xi (Sold)
      03-17-2007, 02:20 PM   #16
uhaulball
Drives: e90 330xi
ooooo.........
that makes even more sense lol!
      03-17-2007, 02:21 PM   #17
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
ooooo.........
:rocks: :rocks: :rocks: :rocks: :rocks:
2006 325xi (Sold)
      03-17-2007, 02:23 PM   #18
montreal_bimmer
OEMconcept
montreal_bimmer's Avatar
Italy
174
Drives: BMW
2006 325i  [10.00]
good find
      03-17-2007, 02:26 PM   #19
HyperM3
Drives: See Sig
Ok, well Ill try it. Worst case scenario is I have to buy the German part for $55.
13 HD FatBob
07 335i(gone)
      03-17-2007, 02:27 PM   #20
Zeiss
Zeiss's Avatar
341
Drives: Bicycle
Great find man!
      03-17-2007, 02:41 PM   #21
enlightenment
Drives: Z4 ///M Coupe AW/IR
Alright... if you guys are going to do this rear fog light mod (which is a great mod, good work ), don't be one of those dumbasses who always puts them on all the time when they are not needed. I always see people in audi's driving like this. I don't think many people understand when to use rear fogs or even know that they turned them on. I'm not saying people on this forum would do that, just be aware and use them appropriately (ie in heavy rain and dense fog).
      03-17-2007, 02:44 PM   #22
uhaulball
Drives: e90 330xi
i plan on using it whenever a huge SUV tailgates me. they tailgate me around here even when im going 60 in a 45.
