328XI Sedan wheel specs
04-18-2011, 10:54 AM | #1 |
Rep 47
Guys, I have a 07 328xi sedan with the stock 16s and am looking to either upgrade to a nicer 17in sport BMW setup or go with some 18s aftermarket.
I'm getting some mixed statements on what the rims size should be...I would have thought with AWD, all wheels should be the same? IE, is 8x17 et 34, 8.5x17 et 37 not correct? Can someone share what the wheel specs should be for both a 17in and 18in setup? Thanks! |
04-18-2011, 11:04 AM | #2 | |
Rep 133
For example I have an 08 328xi with staggered 189s, 18x8/18x8.5. Hope this helps.
2008 E90 328xi | M-tech Front | 189s | LCI Halogens | PE
04-18-2011, 11:05 AM | #3 |
Rep 1,133
Drives: 2008 Jet Black M3 Coupe
Go to Tirerack and enter your car year and model. It will show the optional tire and wheel size for that year.
If you go to the BMW site and configure a new 328xi or 335xi, it will show you what the optional sizes are today. For the xi's or awd cars, the outside diameter has to be almost the same size. width and ratio are less important, with respect to your question about same size. Weight is as important as any other consideration when "upgrading" wheels and tires. |
04-19-2011, 09:48 AM | #6 |
148
Rep 1,728
18x8 with 225/40/18
18x8.5 with 255/35/18 This is the stock xi + sport + 18's setup from the factory.
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
04-19-2011, 12:22 PM | #7 |
Loading...
342
Rep 2,187
Drives: 91' E30 318is
http://www.kouki.co.uk/utilities/vis...ize-calculator
There needs to be <1% difference to not cause damage. |
