N54 335i with premature engine wear
04-19-2011, 12:44 PM | #1 |
Rep 1,133
I have a 2008 335i with 40,000 miles on it. The only mods on the car is a CAI and Dinan stage 2 tune. I've already been through 2 fuel pumps and sets of injectors due to thrown codes in the car. I started noticing a metallic rattling noise when the cars RPM was held around 3000. Car runs great, just an odd noise. BMW dismantled the lower motor to find metal shavings in my oil and a worn main bearing on piston #6. First question is has anyone else had thus problem? Second and the most obvious, is thus something BMW will warranty? The car is never raced or punished and the Dinan just got added about 15,000 miles ago. Thanks for your replies!
04-19-2011, 12:45 PM | #2 | |
3441
Rep 79,211
Oiling problem? |
04-19-2011, 12:45 PM | #3 |
Modder Raider
755
Rep 8,633
Drives: M3
Never heard of this so your the first.
Yes, BMW should cover it.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
04-19-2011, 12:51 PM | #4 |
Rep 1,133
BMW is sending an engineer to look at the car this thursday to decide whats going to be done. As far as oil I change every 7,500. I can't bring myself to wait 15,000 for a turbo motor. As far as who covers it, I'll let everyone know the outcome.....
04-19-2011, 07:44 PM | #7 | |
Rep 1,133
Well I find it odd that they would drop the oil pan and know to look at the main bearings just by telling them of the noise. The noise only occurs around 3000 RPM and when you put it in sport mode and then accelerate to 3000 RPM without letting it shift to the next gear is when you hear the noise. I don't hear it any other times. Does that sound like the wastegate? |
04-19-2011, 07:55 PM | #8 | |
Rep 1,288
Drives: 2014 435iX, FBO
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
04-20-2011, 06:24 AM | #12 |
Rep 2,189
subscribed
lets see if dinan steps up to the plate...
Olds Starfire > Chevy Malibu > Isuzu I-mark RS & Honda Magna 500 > Grand Am GT & YSR50 > Nissan Maxima & Ninja 750 > X-Wife > Hyundai Excel > Honda Prelude > Honda Accord > Honda Prelude & Ninja 250> Infiniti G35 > E90 335i > Hyundai Genesis Rspec, Hyunadai Sonata > Kia Sorento > Honda CRV-EX |
04-20-2011, 09:33 AM | #13 |
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Not necessarily determined yet whether or not the Dinan has anything to do with the bearing failure. I suspect this would have happened without the mild Dinan tune - but let's see who owns up to it.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
04-20-2011, 01:46 PM | #14 | |
Rep 1,133
04-20-2011, 01:54 PM | #15 | |
Rep 1,473
04-20-2011, 04:28 PM | #16 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
BINGO! And #6 cylinder is the hottest one, correct?
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
04-20-2011, 11:15 PM | #17 |
Rep 1,133
Is this true?? I need all the info I can get on the problems with the N54. The engineer from BMW is coming tomorrow to determine if BMW will warranty this motor. I want to be able to show them why this isn't the tunes fault. Thanks for any info anyone has
04-21-2011, 08:45 AM | #18 |
Rep 6,990
Skalberti - the Magnusson-Moss warranty law states that the manufacturer has to prove that the modification caused the problem - it isn't incumbent on you to prove that it did not. That said, there are lots of N54 engines out there with Dinan (and other) tunes that didn't experience this, so if it were me, I'd insist that it was a manufacturing defect - either incorrectly installed or faulty bearing insert material or some other problem. That it was just one bearing instead of all 6 also says something - no. 6 cylinder was "weak" for some reason.
04-21-2011, 09:23 AM | #19 |
Rep 1,998
Although true that the car has a rev limiter, that is for normal up shifts.. There is NOTHING that can stop a mechanical over-rev, as in a 5 to 2 downshift..
Engineer will read DME and get "highest RPM" .... if its significantly over Redline, you may have an issue..... p.s....not saying that you missed a shift... just giving you info. Starved for oil is not really in your control, how do they know it wasent starved for oil at idle ????? and like i said "over rev" is another issue as described above. They will also check that all services were done in a timely fashion..(i.e not wait 2500 miles after service light came on ) If you did in-between oil services on your own, supply those reciepts to show you took "extra care" of the car. p.s.s. what was aid above is true... they have to prove that Dinan tune cause failure and How it did it. If by chance they do, Dinans warranty will kick in..... but i suspect it will be a while.. stand by and be patient.. be prepared, dont go off half cocked. Maybe even call Dinan and make them aware...
X1, R58 JCW, M2 in my future if planets align
04-21-2011, 10:23 AM | #20 | |
Rep 1,133
Thanks for the info roundel335, Its much appreciated! |
04-21-2011, 10:30 AM | #21 | |
Rep 1,133
Thanks drivehard, I actually did in between oil changes at 7,500 and BMW did those oil changes so they have record of that....hopefully. I have an auto trans with the paddle shifters so I can't miss a shift and I can't jump from 5th to 2nd gear. Those are good points though. I have talked to Dan at Dinan and he's been very helpful. He said if the BMW engineer denies warranty to let him know and he will step in. He said either way the car will be taken care of. Thanks again for all the info. Now I just have to sit here patiently waiting to talk to this engineer today.... |
