A testament to run flats
04-19-2011, 03:41 PM | #1 |
Flying Mach .92/Driving E92
Rep 50
Took a few potholes in the last couple of weeks with my 335i Sport Coupe with 19s. The right rear started not holding air so I investigated a bit. I found two bubbles on the outer sidewall. Stopped at the local tire shop looking to replace the four tires (not bad for 20000 miles) and took a peak on the inside of the right rear. I can't believe this is pot hole damage. The RFT still held air!! I'm hoping to get the city to pay up for the damages to the tire and possibly the outer wheel.
04-19-2011, 04:07 PM | #4 |
Rep 1,389
Drives: F80 SO ZCP CCB
potholes +19's can do some serious damage..i just replaced 2 19'' 230's in the rear =(
ouch, it hurts man
A fisherman always sees another fisherman from afar
04-19-2011, 04:09 PM | #5 |
16
Rep 539
04-19-2011, 04:18 PM | #6 |
Rep 154
You are going to need an alignment. I had the same issue. Inside rear driver wore just like that (just not as bad). I won't drive on anything but rfts on my car. I have no issues with them. Good luck getting anything from the City!
04-19-2011, 04:18 PM | #7 |
Rep 40
I have to agree on the tire wear. Almost looks like the tire is rubbing on suspension parts.
As far as the sidewall bubbles I have to mention that if they weren't run-flats they probably wouldnt have bubbled at all. I did both passenger side RFT's going through a pothole after only 7500 miles. I replaced them with Goodyear asemetric's that cost less to reshoe the entire car than to replace the two RFT's. Havent had a problem since and there are some nasty potholes here in LA. |
04-19-2011, 08:33 PM | #12 |
Rep 2,003
Loving rfts for this is like wearing concrete shoes to avoid stepping on thumbtacks
If you had proper tires on, you would have noticed your alignment was totally outta wack |
04-19-2011, 08:54 PM | #13 |
Where'd my VTEC go?
481
Rep 6,067
actually, i've only seen the run flats wear like that on these cars.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
04-19-2011, 09:14 PM | #14 |
Going nowhere fast.
56
Rep 2,243
The camber on a 335i is already set out a few degrees, so its natural for the inside of the tire to wear like that, regardless of RFT or Non RFT. 19's just make the problem worse.....
Bulges in the sidewalls, are a common issues/weakness of the RFT tire, especially Bridgestone. One more reason to never get a RFT. Pot Holes can cause the camber to go off specs, and also cause the sidewall to fail, creating the bulge. Lastly, get some nice summer performance tires and see what the BMW can really feel and handle like, not to mention they last longer, ride smoother and are cheaper to replace. RFT's are for soccer moms... DO NOT drive the car with tires like that, or with bulges, as you are asking for a major blowout, and over 50mph, is damn dangerous. When you get the 4 wheel alignment, use BMW or a shop with the same machine, and get the print out of the specs prior, and after. |
04-19-2011, 09:18 PM | #15 |
Came to the N55 Darkside
1112
Rep 12,740
04-20-2011, 07:07 PM | #17 |
Rep 452
I was originally going to swap out my RFTs to get summer performance tires when I got my car last year, until one day on the way to the Holland Tunnel on the Jersey side I hit a brick laying in the lane on a drawbridge (and no I wasn't able to swerve and avoid it without colliding with on coming traffic).
After the dash went ape shit with lamps going off, the tires held up until I got the car to the sevice center in Brooklyn. Any other tire and I still would be in NJ reading e90post via a mobile. I will however swap out the Bridgestone RFTs for the Michelin PS2 ZP when the tread wears down. |
04-20-2011, 09:18 PM | #18 | |
45
Rep 1,754
Not worth the rim damage, expensive tires, short life, and horrible ride vs. the one-in-a-blue-moon event like you describe. That's why the auto gods made tow trucks! |
04-20-2011, 09:38 PM | #19 |
Happy Camper
613
Rep 7,869
Drives: C63 AMG & 280 SL on Weekends :
Garage List 1969 Restored Merce ... [7.50]
2011 M3 Coupe TRADED [7.34] 1987 BMW 535is [1.00] Cars from the Past [6.50] The ///M3 Engine S65 [9.59] |
I have to agree with the general condenses ... RFT are not ready for our cars, so ditch them ... get normal tires and enjoy the ride. Before you do ... I recommend
A) Check and adjust your camber B) Check your wheels for cracks after a good wash C) Road force balance your wheels Lastly ... do try to avoid loading too much into your trunk and avoid potholes ... no pun intended my friend (I last 2 rear wheels to cracks on my Z4 35i and similar inside wear due to chamber issues and the retractable roof in the trunk [too much weight] that caused the advance inside wear of my tires ... oh ja the RFT that's another story all together). Glad to be in a ///M3 again ... forged wheels and conventional tires, I expect nothing else from the M3 fellows
Cheers, Rolf-Dieter
Life will take us to some interesting places, fortunately The ///M3 will too with a many of us know this very well, now my C6.3 AMG with 487 HP does it too ---> Click here for some good stuff I found |
04-21-2011, 01:33 PM | #20 |
Rep 8
I hit a pot hole recently without run flats and it put a 3 finger sized hole in the sidewall. 45 miles from home late on a Saturday night so was not much fun without a spare (I had a tire repair kit). With a run flat I assume I would at least have been able to limp home even if the tire was toast. Still, I'm not going back - the ride is much better on 18in rims with normal tires, and the taxi home and new non RFT were about the same price as a new RFT :-) I am however, keeping a compact spare in the trunk from now on, unless I'm doing a short trip and really need the space. Even with a run flat, I'd still consider carrying a spare. What happens if I'm 100 miles away from home, and hit a pot hole late on a Friday night? Would the run flat get me through the weekend and then back home?
04-21-2011, 02:52 PM | #21 | |
Rep 452
And tow trucks don't get me to work on time when I get a flat. |
