Battery Replacement for 2007 e92 (335i Coupe)
04-20-2011, 11:32 AM | #1 |
Rep 269
After extensive research on the best place to find a replacement battery for my 335i coupe, I realized there's not much information out there on how to do it.
Most posts I've read said just to take it to the dealer or Costco, but my local Costco doesnt carry a battery for this car yet, and spending extra money at the stealership wasn't in the cards for me. So I finally found a replacement battery at Batteries Plus. It's the Rayovac Maximum with 765 cold cranking amps (versus 720 of the OEM battery), and a reserve capacity of 135 amps. It comes with a 24 month free replacement warranty and a 65 month pre-rated warranty and I paid $149.99 + tax. The installation was fairly straightforward, and the new battery so far has not thrown any codes and I didnt need to take it to the dealership for re-programming (which several posts say you need to do). Here's a link to the battery (which indicates 730 CCA, not 765): http://http://www.batteriesplus.com/...sli94r-li.aspx Hopefully this information is helpful for those looking to avoid overpaying at the stealership!
Retired: '00 e46 (5mt)
Retired: '07 e92 (6mt) Current: '08 S2000 (6mt) Current: '17 Porsche Macan GTS Current: '04 V8 4Runner |
04-20-2011, 12:17 PM | #2 |
Rep 3,969
I'm with you OP, but look out, here come the fear mongers with stories/links about trunk lids being blown off by exploding batteries, cars just dying in the middle of the highway, and entire electrical systems having to be replaced for thousands of dollars...just because you used a non AGM battery and did not register it. Hurry up, perhaps you can still make it to the dealer in time before the car turns into a worthless pile of metal, rubber and glass!
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
04-20-2011, 12:38 PM | #3 |
1911
Rep 13,104
AGM is not on all cars
Only the ones with most of the options get it as far as I understand it.
I would get an Indy or someone with a scanner to register it if I could. |
04-20-2011, 01:34 PM | #4 | |
NHTSA Nazi
28
Rep 1,983
04-20-2011, 02:14 PM | #5 |
Rep 1,029
Drives: 2019 440xi Gran Coupe
I know that I have to change my battery soon since its still the original and my car is an 06 and this winter there were a few times where I had to boost my car.
I was told by the BMW SA that not all batteries need to be registered. It only applies to certain year and models. I have a 2006 325i and was told that my car's battery did not have to be registered. The only problem I might encounter is that I would have to register the car radio after the battery install or else it won't work. I don't always trust the words of a SA but please chime if he's totally off the charts. Thanks! |
04-20-2011, 09:41 PM | #6 | |
El Greco Capitan
309
Rep 1,051
I bought mines from pep-boys. They carry the oem spec one (Bosch) for 07" 35i E92. I didn't know about registering, 2 weeks later I got flicker lights, sounds, a cranking effort and then it all went dark. I got a Jumpstart run home, Used my Bavtool to reg and no issues at all after that. Best of luck.
No, it's not new. It got 150.000+ miles on it
03-22-2012, 11:13 AM | #7 |
Rep 128
Are the agm ones the white top ones??
I was going to purchase this one : http://www.autozone.com/autozone/par...9458_351737_0_ For my 07 335i with idrive navigation and comfort access. |
03-22-2012, 01:29 PM | #8 | |
Rep 876
Car pics HERE |
03-22-2012, 01:51 PM | #9 |
Rep 3,854
Drives: 330i, 135i
Any info on this battery replacement issue is appreciated. Prices etc... I know I will need to replace mine sometime soon. For the last 2 years I get a yellow battery icon if I keep my radio on for more than 3 min or so after the car is shut off. No problems starting or anything. Its a stock battery still so I can consider myself lucky I guess...I wonder if i will need to register it.
03-22-2012, 01:52 PM | #10 | |
Rep 3,969
http://www.e90post.com/forums/showpo...8&postcount=18
03-22-2012, 02:50 PM | #11 | |
Rep 128
03-21-2013, 03:25 PM | #12 | |
Rep 127
Battery @ $207 and install @ $208 @ 2 hr of install. Can anyone one tell me if this sound right? |
03-21-2013, 03:42 PM | #13 | |
El Greco Capitan
309
Rep 1,051
It cost me $180 at pepboys, 5 min install time....You do have to register the Battery though, got a Bav tech tool available? post in your region forum and ask, sure someone can register it for you. |
03-21-2013, 04:04 PM | #14 | |
Rep 3,854
Drives: 330i, 135i
2 hrs of install.... |
08-12-2014, 12:09 PM | #15 | |
Rep 130
Drives: e92 335i Coupe w M Sport Kit
09-13-2014, 11:58 PM | #16 | |
Rep 125
Did you get this one Bosch Premium Performance Battery Group Size H6/L3/48 or Bosch Premium Performance Battery Group Size 94R? |
