Max Wheel Size On E92 Coupe
04-23-2011, 07:11 PM | #1 |
Rep 434
Want to know what the max wheel size is I can fit on 335i coupe w/o fender rolling..
295/25/20 ? 305/25/20 ? Need to know asap Thanks for all your help in advance |
04-23-2011, 07:43 PM | #2 |
ENTHUSIAST
135
Rep 2,097
Drives: 2010 Porsche Cayman
I've got 275's out back and I believe that's all you can get without rolling.
"what I'm driving here...is an ending." Jeremy Clarkson
2010 Carrara White Porsche Cayman 6mt 2014 Whiteout Toyota GT-86 6mt(Sold 05/23/15) 2011 Alpine White BMW M3 6mt ZCP Coupe(forced retirement 06/06/14) 2008 Alpine White BMW 328i 6mt Coupe(retired 06/21/11) |
04-23-2011, 08:04 PM | #3 |
Rep 434
Thanks for your input..
I've been getting mixed responses from Rim shops.. Some say we have done 305's and 295s with no rolling... So say dont go past 285.. Need someone to Verify please! |
04-23-2011, 08:38 PM | #4 |
COBB'ed
65
Rep 2,228
I have 275's and there's not much room left down there. I think 285's are doable, but do it at your own risk.
13 Mini Cooper S 08 E92 335i (SOLD) |
04-24-2011, 12:27 AM | #6 |
Rep 502
You MIGHT be able to do larger but you would have to have a very high offset or probably >43 or so. I test fitted 275/30/19 today and there was only about 1 fingerbreadth between tire and fender at 38 offset.
Also with a 19" wheel you have 19*25.4mm/inch = 482.6mm just with wheel alone. With 20" wheel it is 508mm. Add the width of the tire to these to get total height. If you run 285/25 that means .25 * 285mm = 71.25mm additional. With a 508mm wheel (20") thats 579.25mm TOTAL. With my test fit today of 275/30 on 19 inch rim I had .30 * 275mm = 82.5 mm added to the 482.6 mm wheel (19") = 565.1mm TOTAL. With that I only had one fingerbreadth room. My finger is definitely NOT 14.15mm thick (which is the difference in TOTALS above). That would be an additional .56 inches tall!! Seems very hard to stuff all that underneath unless you use HUGE offset. Your best bet is to go to the wheel/tire shop and have them test fit a wheel with the tires you want....but I dont think you can stuff that under the fender. |
04-24-2011, 09:55 AM | #7 | |
1569
Rep 29,202
19" - 82.5 + 82.5 + 482.6 = 647.6 20" - 71.25 + 71.25 + 508 = 650.5 |
04-24-2011, 10:43 AM | #8 |
ENTHUSIAST
135
Rep 2,097
You are 100% on the money. I have just a smidge over 1 finger room with this setup. That's all you need for no rubbing or drama.
04-24-2011, 12:50 PM | #9 |
Where'd my VTEC go?
481
Rep 6,067
it all depends on the width and offset of your wheel. tire width doesnt mean much without the other info.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
04-24-2011, 02:18 PM | #10 | |
Rep 502
04-24-2011, 03:02 PM | #11 | |
1569
Rep 29,202
I'm talking about the overall diameter of a wheel with tire, of course you have to add the tire sidewall height twice.
04-24-2011, 08:54 PM | #12 |
Rep 502
04-25-2011, 04:57 PM | #13 |
1569
Rep 29,202
You do know that the diameter of a 19" wheels are more than 19" when you measure it, it's probably 20" to 20.5" in diameter. It's the opening in the tire that's 19" so natural the wheel is a little bigger.
