BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Can I use the factory wiring to the front door speakers for my components?
      04-27-2011, 06:54 AM   #1
neusaab
Drives: 2007 335xi
I finally bit the bullet and ordered an MS-8. Will get a harness from Technic when the backorder fills.
I'll probably get a pair of DLS RS5 components for the front door/sail panels. I'll power them with the MS-8. This is going into an 07 335/Logic 7.
Can I use the factory wiring to the front doors for this application?
Also, not yet having read the MS-8 manual, do I need to find 2 ohm speakers for the front doors, or can I use 4 ohm units with the remaining Logic 7 2 ohm speakers?
Thanks.
      04-27-2011, 08:23 AM   #2
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
The OEM speaker wire is thick enough for aftermarket speakers and amps. Before you buy the DLS speakers, hook up the MS-8 and see if you still find the need to upgrade. Also, you should install a tweeter next to the center speaker for best result. The MS-8 works well with 2 ohm speakers and it will make a huge improvement as long as the factory speakers are of decent quality, which they are in the L7 system. If you go with aftermarket speakers, the overall volume level will drop as a result of the the difference in efficiency and impedance.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
      04-27-2011, 09:19 AM   #3
neusaab
Drives: 2007 335xi
Thanks, I've read your extensive posts which are helpful. I am skeptical that the L7 speakers will satisfy me, but I see your point about listening first, as the front speaker replacement job is not the easiest. Certainly helps to be able to use the factory wiring.
So, to confirm, later adding a 4 ohm speaker will affect volume, but the MS-8 will be able to handle this?
      04-27-2011, 09:41 AM   #4
kmarei
kmarei's Avatar
Egypt
687
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
it will but it ill put out less power into 4ohm than 2ohm
try the logic 7 speakers with the MS-8
they really are good
      04-27-2011, 10:28 AM   #5
neusaab
Drives: 2007 335xi
Stock wiring for underseat woofers?
Thanks for the reinforcement, I'm gonna give the L7's a chance.
I am definitely replacing the underseats, SWS8's, I think. I'll drive them with an Xtant 403a amp that I have. I assume I want the 4 ohm model? I am thinking about the 2 ohm version only because I could use them with the stock amp/MS-8 until I do the amp install.
How about using the stock wiring for the replacement underseats?
