20MM Spacers with VMR V710s?
04-27-2011, 04:11 PM | #1 |
Rep 722
Looking to get 20MM Spacers for my 19 inch VMR V710s on the rear, doesn't look aggressive enough to me. The tire is 265/30/19 i believe its +22 offset or maybe +30 not sure, just want to make sure that 20MM won't make the tire rub?
04-27-2011, 04:43 PM | #2 |
375
Rep 17,017
20mm will be way to aggressive for either of those offsets if they are 9.5" wide. Either offset should be flush or even a little beyond the fender and should not need spacers.
04-27-2011, 05:22 PM | #3 |
BimmerPost Supporting Vendor
2042
Rep 25,989
Seeing that you have an 09 335i, is it a Sedan? If so, you may have the 9.5 +45's which does give you some slight room to throw a spacer on. I would recommend measuring the tire sidewall to fender clearance and purchase accordingly.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
04-27-2011, 05:23 PM | #4 | |
79
Rep 1,682
Running a 265 with +2 offset is gonna be difficult if not impossible. You need skinnier tires if you plan on going more, unless your riding on 4x4 suspension? |
04-28-2011, 11:56 AM | #5 |
1569
Rep 29,202
Might want to start with 10mm, 20mm is a pretty fat spacer that will most surtainly make it rub.
