Powering 2x 120mm fans with MS-8
04-28-2011, 06:29 AM | #1 |
Rep 4,121
Folks, I have a triple stack (2 amps and MS-8) in my CD changer compartment, I want to put two 120mm fans in there. Would the REM OUT 12v of the MS-8 be able to supply enough current (about 0.5A for two) to run two little fans?
Any other suggestions? I thought about wiring the euro cig lighter to that side of the trunk also. |
04-29-2011, 02:56 PM | #4 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
current limit on the remote out of the MS-8 is 1amp
so if it's 0.5A for both fans you should be good i'd recommend 2x 140mm fans they usually consume less current generate more air and don't spin as fast so less noise |
04-29-2011, 07:17 PM | #6 |
Rep 4,121
04-30-2011, 07:56 PM | #7 |
29
Rep 1,551
Well its because you dont want to draw any extra current that a circuit isnt designed for, and you will in turn blow a fuse. A relay is an electronic switch. Use the remote wire to switch a 12V 5A relay (overkill but cheap anyway) and youll be fine.
04-30-2011, 08:05 PM | #8 |
Rep 6,845
I prefer this to using a relay
Easier to hookup Up to 2 amp is ok http://www.sonicelectronix.com/item_18693_PAC-TR-4.html |
08-03-2011, 12:58 PM | #9 |
Rep 78
correct me if im wrong, but shouldnt the cigarette lighter be ok for a a remote lead plus fan? lets say the cig lighter is never used. after intial startup the only current would be to the fan right? or is there always current to the amp remote lead after its turned on. i was trying to stay away from a head unit connection, and another battery connection.
08-14-2011, 06:36 PM | #10 | |
Rep 399
The amp turns on even before that. It turns on as soon as you unlock the doors and stays on for a few minutes after they key is removed, for it's the stereo system that makes the "gong" sound. I ran fans off the turn on lead for this reason (using Technic's harness which is relayed from the OEM Hi-Fi turn on lead and amp power wire).
-David
08-14-2011, 08:39 PM | #11 | |
Rep 4,121
